Hi everyone, I'm working on a clock project with an RTC. The RTC drops its SQW pin low when the alarm fires, and I'd like to wake the arduino and update the clock when that happens. I'd also like to wake the arduino if the button is pressed to set the time. I tried playing around a little but neither works well. I'm very new to this so if you're willing to help and provide an example as to how to fix it, I'd REALLY appreciate it. Thank you all so much!
#include <SPI.h>
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 8);
int loopWait = 0;
bool needsUpdate = true;
pinMode(3, INPUT_PULLUP); //set time button
pinMode(9, INPUT_PULLUP); //set time button
//Initial RTC calls
rtc.begin(10);
rtc.set12Hour();
rtc.autoTime(); //Get time automatically
pinMode(2, INPUT_PULLUP); //Set interrupt for alarm
attachInterrupt(digitalPinToInterrupt(2), alarm, FALLING);
rtc.update(); //Update + Set alarms
rtc.enableAlarmInterrupt();
rtc.setAlarm2(rtc.minute() + 1);
//Initial display calls
display.begin();
printClock(rtc.hour(),rtc.minute());
void alarm() {
updateClock();
rtc.update();
//static int8_t lastMinute = -1;
/*if (rtc.minute() != lastMinute) {
printClock(rtc.hour(), rtc.minute());
lastMinute = rtc.minute();
rtc.setAlarm2(rtc.minute() + 1, rtc.hour());
if (digitalRead(3) == LOW) {
setTime();
if (digitalRead(9) == LOW) {
loopWait++;
if (loopWait >= 4) {
display.clearDisplay();
display.setFont(&FreeSansBold12pt7b);
display.setCursor(5,30);
display.println("Prom?");
display.display();
loopWait = 0;
void setTime() {
rtc.update();
int hour = rtc.hour();
int minute = rtc.minute();
int day = rtc.day();
int date = rtc.date();
int month = rtc.month();
int year = rtc.year();
bool pm = rtc.pm();
delay(200);
display.setFont();
display.setTextSize(1);
display.setTextWrap(true);
display.println("Entering time set mode. Press to contuinue...");
display.display();
//SET DAY
while (true) {
if (day == 7) {
day = 0;
day++;
delay(200);
display.setCursor(15,20);
switch(day) {
case 1:
display.println("SUNDAY");
case 2:
display.println("MONDAY");
case 3:
display.println("TUESDAY");
case 4:
display.println("WEDNESDAY");
case 5:
display.println("THURSDAY");
case 6:
display.println("FRIDAY");
case 7:
display.println("SATURDAY");
display.display();
} else if (digitalRead(9) == LOW) {
display.display();
//SET MONTH
display.println("MONTH");
display.display();
while (true) {
if (month == 12) {
month = 0;
month++;
delay(200);
switch(month) {
case 1:
display.println("JANUARY");
case 2:
display.println("FEBRUARY");
case 3:
display.println("MARCH");
case 4:
display.println("APRIL");
case 5:
display.println("MAY");
case 6:
display.println("JUNE");
case 7:
display.println("JULY");
case 8:
display.println("AUGUST");
case 9:
display.println("SEPTEMBER");
case 10:
display.println("OCTOBER");
case 11:
display.println("NOVEMBER");
case 12:
display.println("DECEMBER");
display.display();
display.display();
display.println("DATE:" + String(date));
display.display();
Serial.println("set date");
//SET DATE
while (true) {
if (date == 31) {
date = 0;
date++;
delay(200);
display.display();
display.display();
display.setCursor(0,20);
display.println("YEAR after 2000: " + String(year));
display.display();
//SET YEAR
while (true) {
if (year == 99) {
year = 16;
year++;
delay(200);
display.display();
display.display();
printClock(hour, minute);
display.setCursor(35,0);
display.setFont();
display.setTextWrap(false);
if (pm == true) {
display.println("PM");
display.display();
display.println("AM");
display.display();
//SET HOUR
while (true) {
if (hour == 12) {
hour = 0;
pm = !pm;
hour++;
delay(200);
display.setFont();
if (pm == true) {
display.display();
display.display();
//SET MINUTE
while (true) {
if (minute == 60) {
minute = 0;
minute++;
delay(200);
if (pm) {
rtc.setTime(0, minute, hour, PM, day, date, month, year);
rtc.setTime(0, minute, hour, AM, day, date, month, year);
Serial.println("Time set for " + String(hour) + ":" + String(minute) + " on " + String(date) + " " + String(month) + " " + String(year));
display.setFont();
display.println("Time set");
display.display();
delay(2000);
void printClock(int hour, int minute) {
display.setFont(&FreeSansBold18pt7b);
if (hour >=10) {
display.setCursor(-3,35);
display.setCursor(9,35);
if (minute < 10) {
display.println(String(hour) + ":0" + minute);
display.display();
display.println(String(hour) + ':' + minute);
display.display();
printHeader();
printFooter();
void updateClock() {
rtc.update();
I had to omit some code, the entire code is on pastebin here: https://pastebin.com/igaqnYTw.
NOTE: I haven't implemented sleep code yet, but I'd assume I need to use interrupts in order for the device to ever wake out of sleep. Any advice on that would also be appreciated! Thanks!
