I did somthing stupid or its just I dont know what Im doing... All I need is when "button 1 - 4" is pressed it should display in the serial and on my lcd. I wanted to use funtions because its cleaner and I am writing non blocking code after for the first time and I know its going to be complicated. I already tested everything (button and lcd WORKING)
button has a pull down resistor
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define button1 6
int bV1;
#define button2 7
int bV2;
#define button3 8
int bV3;
#define button4 9
int bV4;
lcd.begin(16, 2);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
pinMode(button4, INPUT);
bV1 = digitalRead(button1);
bV2 = digitalRead(button2);
bV3 = digitalRead(button3);
bV4 = digitalRead(button4);
buttonPressed;
void buttonPressed(){
lcd.write("BUTTONPRESSED FUNTION");
Serial.print("BUTTONPRESSED FUNTION");
if(bV1 == 1){
Serial.println("BUTTON 1 PRESSED");
lcd.setCursor(0,0);
lcd.print("BUTTON 1 PRESSED");
else if(bV2 == 1){
Serial.println("BUTTON 2 PRESSED");
lcd.setCursor(0,1);
lcd.print("BUTTON 2 PRESSED");
else if(bV3 == 1){
lcd.setCursor(0,0);
Serial.println("BUTTON 3 PRESSED");
lcd.print("BUTTON 3 PRESSED");
else if(bV4 == 1){
lcd.setCursor(0,1);
Serial.println("BUTTON 4 PRESSED");
lcd.print("BUTTON 4 PRESSED");
I dont know how to use a funtion properly sorry
also I did some messing arround thats why the code is so messy and out of place
Thanks for reading!!!
Edit: fixed up some code so its less messy
