Calling method with *parameter
I have some code that calls a method that accepts a char *text.
void bar() {
  foo("0123");
  String text = "0123";
  foo(text);
void foo(const char *text) {
  // Do stuff
It compiles if I pass it a string literal, but if I pass it a string variable it throws a compile time exception:
cannot convert 'String' to 'const char*' for argument '1' to 'void foo(const char*)'
   foo(text);
The error message tells you exactly what is wrong. Don't use a String, use a C style string instead
  char * message = "0123";
  foo(message);
  Serial.println(text);
Do not use the "String" class on AVR based boards, it will most likely cause problems at some point. If you have to, use "String.c_str()" to get a "char*" string.
I understood the message, I didn't understand why the string literal worked but the String type didn't. Now I know, String is a different type to "Foo". I thought it was odd that String was capitalised.
Is "Foo" of type char *?
Actually that throws a compile-time exception:
 warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
The foo() function requires a parameter that is a pointer to a C style string (lowercase s) . This could be either a string variable, which is itself a zero terminated array of chars, or a string constant in quotes
  char * message = "from the message array";
  foo(message);
  foo("this is a string constant");
If I make the declaration a const then things are happy.
  const char * message = "0123";
  foo(message);
I need to be able to pass it a variable though, do I need to put my variable into a const before passing it to the method? e.g.
char * foo = "1";
const char * bar = foo;
No. Try this:
  char message[] = "0123";  //note brackets
  foo(message);
void foo(char *text)
The const tells the compiler that the foo function will not alter what the char* points to. You can pass a char* that is not const without any problems, you just cannot pass a const char* to a function that takes a char* because the function is not prohibited from altering it.
This is your problem:
The 'char * message' part means that 'message' is a pointer to a char and the char (or chars) being pointed to can be modified via the pointer.
The compiler doesn't like that since you're pointing 'message' at a string literal that should never be modified.
As you discovered this fixes it:
Now you can't modify the literal via the pointer.
or use:
or
const char message[] = "0123";
All of the above can be used in a call to your function:
  // Do stuff
