Calling parent function
I am trying to implement a call for a parent class function without success.
the base class is :
class Base
public:
    Base();
     child *children;
    float theDelegate(char *arg);
Then the child needs to declare its parent with :
class child: public Base
public:
But in order for the child to see Base , I must include the Base class in the child (other wise I get an error that he does not know Base)
but this #include "Base.hpp" , will cause an error on the Base, since they include each other.
(error is on line child *children; saying unknown type name Child" ).
How can i resolve this ?
gil22:
Check your capilatization, unless you typed that from memory and didn't copy+paste.
Do you have include guards in your header files? They are a must for exactly this reason.
Children do not necessarily have to be a derived type of the parent. A little less abstraction and a lit more specifics can help use see if this is an example of the X-Y problem.
You must include base.hpp in child.hpp, but do not include child.hpp in Base.hpp. Simply add a forward declaration of the child class above the base class in base.hpp:
class child;
That's it.
If I remove the include of the child from the parent I get errors because obviously he can not see it now , even if I add the "class child"
class Base;
class Base
public:
    Child *child;
.cpp
    child =new child(built);   // ** error - allocation of incomplete type child
gil22:
class Child;  //  <-- !!! Like this here !!!
class Base
public:
Child *child;
.cpp
Also, your capilization seems to be all over the place. Are you class names in uppercase, or the object names? Fix it. C++ is sensitive to that.
Ok I still struggle with errors , maybe you can spot what it is, so , there is the parent class :
parent .h
class Child;
class Parent
public:
    Parent();
    int sendData(char*cmd);
    EEprom *eeprom;
    Child *intepreter;
The Parent .m :
Parent:: Parent()
    char *builts[]={"me","you",NULL };
    eeprom=new EEprom();
    intepreter=new Child(built);   /// if I remove the include there is error here !
The the child is like this (.h)
#include "Parent.hpp"
class Child  : public Parent
Removing the include child , from the parent , will cause parent to not recognise when I try to construct the child.
To fix your immediate problem, #include "child.h" in parent.cpp (not the header, the source file).
There may be a deeper issue though. What are these classes doing? Does Child need to inherit from Parent? Currently, this example is very abstract so I can't help you with that.
I don't mean this to be rude, but since you are having this much trouble with such a basic thing like what headers are supposed to be included in which files, I don't have any confidence that you understand what inheritance is for and are using it properly. You may be confusing the Base->Derived relationship that inheritance is for with the Parent->Child relationship that is implemented in a different way. Children of a class do not have to be a derived type of the class.
The common term for this is the "X-Y" problem. In short, you want to do X, and think Y is the way to do it, so you ask questions about Y. However, all the good help in the world won't matter if Y isn't a proper way to do X.
You're telling us Y. Tell us X instead, and we can help make the proper class design for what you want to do.
The fact that you need to make that kind of circular reference is a good indication that your class hierarchy is seriously flawed, and you need to put more thought into how you abstract things. Data/information flow should be one direction.
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
I think that statement is quite a lot stronger than it needs to be. There are perfectly valid reasons why you might have circular calling references like that.
For example, at my job we have a particular piece of software that uses what is called a utility file that contains interpreted instructions that direct the program to perform certain sequences of events. The file contains a numbered sequence of steps, and each set has a set of goto fields that say which step number to go to next depending on the result of the step.
To help programmatically generate these files, I created my own program with separate classes called utility, step, and goto_field.
For the goto field, I created 3 different ways of referring addressing the step that would be converted to the proper step number when it was written out to file: absolute (Step #), relative (next step, or 3 steps back), and pointer (this specific step, no matter where it may be rearranged in the list).
So suppose I have a goto_field referring to a step by its pointer, and the step it's pointing to is deleted in the course of the utility object. I now have a dangling pointer to something that no longer exists. How do I fix that?
The easiest way I came up to do it was to have the step class track all the goto_fields that were pointing to it. When the goto field pointed to the step, it called a step::register_reference function that added a pointer to itself to the step's list. When it no longer pointed to that step (or was destroyed) it unregistered the reference.
In step's destructor, I have it loop through all the references in the list and call the set_invalid() function to set the goto's reference pointer to nullptr.
So step is calling functions on goto_field pointers, and goto_fields are calling functions on step pointers.
