Hola, buenas tardes tengo un codigo que estoy implementando funciona casi a la perfeccion, solo que no logro cambiar de grados centigrados y grados Fahrenheit por medio del boton selector, en modo touch, podrian checar que esta mal del codigo de antemano muchas gracias, saludos.
Este es el codigo.
// Using the DHT22 Temp/Humidity sensor with an MCUFriend 3.5" 480x320 TFT LCD
// Draws a thermometer bulb graphic and shows humidity on an analog meter needle display
// Based on Adafruit sensor library example sketches
// REQUIRES the following libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
// Graphical display inspired by the sketch/project:
// Bar Graph Digital Thermometer Using TFT LCD Touch Screen (Arduino Based)
// http://basicarduinotutorial.blogspot.com/2017/08/project-ii-16-bar-graph-digital.html
// On-screen button interface is based on the button_simple.ino demo sketch included with
// the MCUFRIEND_kbv library
// For more details and a schematic, refer to
// https://github.com/GadgetReboot/Arduino/tree/master/Uno/DS18B20_TFT_LCD
// Tested with Arduino IDE v1.8.9
// Adafruit Unified Sensor v1.0.3
// DHT Sensor Library v1.3.4
// Adafruit GFX Library v1.5.1
// MCUFriend kbv v2.9.8
// Adafruit Touchscreen v1.0.1
// Gadget Reboot
#include "DHT.h"
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#define DHTPIN 51 // digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // can be DHT11, DHT21, DHT22
// create a DHT sensor object
DHT dht(DHTPIN, DHTTYPE);
// run TouchScreen_Calibr_native.ino in MCUFRIEND_kbv examples to calibrate screen
// copy calibration data from serial monitor for XP, XM, YP, YM, TS_LEFT, TS_RT, TS_TOP, TS_BOT
const int XP = 7, XM = A1, YP = A2, YM = 6; //320x480 ID=0x0099
const int TS_LEFT = 903, TS_RT = 163, TS_TOP = 947, TS_BOT = 165;
MCUFRIEND_kbv tft; // create display object
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300); // create touch screen object
// assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GRAY 0xC618
#define DARKGRAY 0x6B0C
// touch pressure sensitivity thresholds to detect screen presses
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// used to control/check if units should be displayed in C or F (makes code more readable)
#define degC false
#define degF true
// misc variables
uint16_t tsID; // touch screen driver type ID
int pixel_x; // touch screen pressed location
int pixel_y; // touch screen pressed location
uint8_t Orientation = 0; // portrait screen orientation
int prevTempLevel = 0; // store last thermometer reading level
bool TempAmbUnits = degC; // default to displaying in degrees C
float humidity; // humidity sensor reading
float TempAmb; // temperature sensor reading
unsigned long timeInterval = 2000; // time interval between DHT readings in mS
unsigned long timeLapsed; // time lapsed since last timer expiry
// humidity gauge
#define meterScaling 1.3333 // resize the meter if desired
float ltx = 0; // saved x coord of bottom of needle
uint16_t osx = meterScaling * 120, osy = meterScaling * 120; // saved x & y coords analog meter
uint32_t updateTime = 0; // time for next update
int old_analog = -999; // value last displayed
int value[6] = {0, 0, 0, 0, 0, 0};
int old_value[6] = { -1, -1, -1, -1, -1, -1};
// thermometer graphic coordinates and size
#define thermXTop 200 // thermometer tube top center x coordinate
#define thermYTop (meterScaling * 126) + 115 // thermometer tube top center y coordinate
#define thermHeight 160 // thermometer tube height
#define thermTubeWidth 24 // thermometer tube width
#define thermBulbRadius 24 // thermometer bulb radius
// create two touch screen buttons
Adafruit_GFX_Button degC_btn;
Adafruit_GFX_Button degF_btn;
void setup(void) {
// initialize the DHT sensor
dht.begin();
// initialize Touch Screen
tft.reset();
tsID = tft.readID(); // find what driver is on the TFT LCD
tft.begin(tsID);
tft.invertDisplay(true); // invert screen colors if this driver requires it
tft.setRotation(Orientation); // set portrait or landscape mode
tft.fillScreen(WHITE); // clear the screen
// display box for numerical temperature and humidity
// y-position is offset by meterScaling*126, which is the y-height of the humidity gauge
// so re-sizing the gauge allows other graphics to be drawn in relation to gauge at top of screen
tft.drawRect(10, (meterScaling * 126) + 10, 300, 75, BLACK);
tft.fillRect(15, (meterScaling * 126) + 15, 290, 65, WHITE);
tft.setTextColor(BLACK, WHITE); // printer header text
tft.setTextSize(2);
tft.setCursor(20, (meterScaling * 126) + 25);
tft.print("Temperatura Humedad");
// main thermometer graphic display box area
tft.drawRect(10, (meterScaling * 126) + 90, 300, 220, WHITE);
tft.fillRect(15, (meterScaling * 126) + 95, 290, 210, WHITE);
// draw thermometer background graphics
drawThermometer();
// set up two on-screen buttons to switch between deg C and F
degC_btn.initButton(&tft, 80, (meterScaling * 126) + 160, 100, 40, WHITE, CYAN, BLACK, "deg C", 2);
degF_btn.initButton(&tft, 80, (meterScaling * 126) + 220, 100, 40, WHITE, CYAN, BLACK, "deg F", 2);
degC_btn.drawButton(false);
degF_btn.drawButton(false);
// draw humidity gauge background graphics
analogMeter();
plotNeedle(0, 0);
// if it is time to read from the DHT sensor, take a temp/humidity reading
if (millis() - timeLapsed > timeInterval) {
// reading temperature or humidity takes about 250 milliseconds
// read humidity
humidity = dht.readHumidity();
// read temperature: TempAmbUnits true=degF false=degC
TempAmb = dht.readTemperature(TempAmbUnits);
// check if any reads failed
if (isnan(humidity) || isnan(TempAmb)) {
Serial.println(F("Failed to read from DHT sensor!"));
else {
Serial.print(F("Humidity: "));
Serial.print(humidity);
Serial.print(F("% Temperature: "));
Serial.print(TempAmb);
if (TempAmbUnits == degC) {
Serial.print(F("°C "));
else {
Serial.print(F("°F "));
// display temperature and humidity numerically in header box
tft.setTextSize(3);
tft.setCursor(30, (meterScaling * 126) + 50);
tft.print(TempAmb, 2); // 2 decimal places
tft.print((char)247); // degree symbol
tft.setTextSize(3);
tft.print("C ");
tft.print("F ");
tft.setCursor(190, (meterScaling * 126) + 50);
tft.print(humidity, 2); // 2 decimal places
tft.print("%");
// update thermometer level graphic if temperature is within graphical range
if ((TempAmb <= 100 ) && (TempAmb >= 0 )) {
int curTempLevel = map(TempAmb, 0, 100, 0, (thermHeight - (thermBulbRadius)));
// update thermometer level if height has changed
if ((prevTempLevel - curTempLevel) != 0) {
// draw new red level
tft.fillRect((thermXTop - (thermTubeWidth / 2) + 6),
thermYTop + ((thermHeight - (thermBulbRadius) - curTempLevel)),
(thermTubeWidth - 12),
curTempLevel,
RED);
// draw new white background above red level height in tube
tft.fillRect((thermXTop - (thermTubeWidth / 2) + 3),
thermYTop,
(thermTubeWidth - 6), (thermHeight - (thermBulbRadius) - curTempLevel),
WHITE);
prevTempLevel = curTempLevel; // store bar height for next iteration
timeLapsed = millis();
// update analog humidity meter needle
plotNeedle(humidity, 10);
// check if either of the on screen buttons are pressed and
// change between deg C and F display as required
bool buttonPressed = Touch_getXY();
degC_btn.press(buttonPressed && degC_btn.contains(pixel_x, pixel_y));
degF_btn.press(buttonPressed && degF_btn.contains(pixel_x, pixel_y));
if (degC_btn.justReleased()) // switch to showing degrees C
degC_btn.drawButton();
if (degC_btn.justPressed()) {
degC_btn.drawButton(true);
if (degF_btn.justReleased()) // switch to showing degrees F
degF_btn.drawButton();
if (degF_btn.justPressed()) {
degF_btn.drawButton(true);
TempAmbUnits = degF;
} // end void loop()
// get touch screen pixel location if screen is touched
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); // restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); // because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); // map x location from analog pos. reading to screen width
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height()); // map y location from analog pos. reading to screen height
return pressed;
// draw the background graphics for the thermometer and markings
// this is only drawn once, then the temperature bar is adjusted as needed
void drawThermometer(void) {
// draw thermometer tube outline
tft.fillRoundRect((thermXTop - (thermTubeWidth / 2)), thermYTop - (thermTubeWidth / 2) + 1,
thermTubeWidth, thermHeight, thermTubeWidth / 2, BLACK); // tube
tft.fillCircle(thermXTop, (thermYTop + thermHeight), (thermBulbRadius), BLACK); // bottom bulb
// fill white thermometer tube inside
tft.fillRoundRect((thermXTop - (thermTubeWidth / 2) + 3), thermYTop - (thermTubeWidth / 2) + 5,
(thermTubeWidth - 6), thermHeight, (thermTubeWidth / 2) - 0.5, WHITE); // tube
tft.fillCircle(thermXTop, (thermYTop + thermHeight), (thermBulbRadius - 3), WHITE); // bottom bulb
// fill red thermometer bulb
tft.fillCircle(thermXTop, (thermYTop + thermHeight), (thermBulbRadius - 6), RED);
// fill red tube to connect between lowest reading level and the bulb reservoir
tft.fillRect((thermXTop - (thermTubeWidth / 2) + 6), thermYTop + thermHeight - thermBulbRadius, (thermTubeWidth - 12), 7, RED);
// draw line markings beside thermometer for visual reference levels
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, thermYTop, 8, 2, BLACK); // top level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.75), 5, 2, BLACK); // 1/4 from top
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.50), 8, 2, BLACK); // center
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.25), 5, 2, BLACK); // 1/4 from bot
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, ((thermYTop + thermHeight) - thermBulbRadius), 8, 2, BLACK); // bottom level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.95), 3, 2, BLACK); // "5" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.90), 3, 2, BLACK); // "10" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.85), 3, 2, BLACK); // "15" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.80), 3, 2, BLACK); // "20" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.70), 3, 2, BLACK); // "30" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.65), 3, 2, BLACK); // "35" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.60), 3, 2, BLACK); // "40" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.55), 3, 2, BLACK); // "45" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.45), 3, 2, BLACK); // "55" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.40), 3, 2, BLACK); // "60" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.35), 3, 2, BLACK); // "65" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.30), 3, 2, BLACK); // "70" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.20), 3, 2, BLACK); // "80" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.15), 3, 2, BLACK); // "85" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.10), 3, 2, BLACK); // "90" level
tft.fillRect(thermXTop + (thermTubeWidth / 2) + 1, (thermYTop + (thermHeight - thermBulbRadius) * 0.05), 3, 2, BLACK); // "95" level
// draw thermometer level indicator numbers
tft.setTextColor(BLUE);
tft.setTextSize(2);
tft.setCursor(((thermXTop + (thermTubeWidth / 2)) + 10), (thermYTop - 5));
tft.print("100");
tft.setTextSize(2);
tft.setTextSize(2);
tft.setCursor(((thermXTop + (thermTubeWidth / 2)) + 10), (thermYTop + (thermHeight - thermBulbRadius) * 0.25) - 5);
tft.print("75");
tft.setTextSize(2);
tft.setTextSize(2);
tft.setCursor(((thermXTop + (thermTubeWidth / 2)) + 10), (thermYTop + (thermHeight - thermBulbRadius) * 0.5) - 5);
tft.print("50");
tft.setTextSize(2);
tft.setTextSize(2);
tft.setCursor(((thermXTop + (thermTubeWidth / 2)) + 10), (thermYTop + (thermHeight - thermBulbRadius) * 0.75) - 5);
tft.print("25");
tft.setTextSize(2);
tft.setTextSize(2);
tft.setCursor(((thermXTop + (thermTubeWidth / 2)) + 10), (thermYTop + thermHeight - thermBulbRadius - 5));
tft.print("0");
tft.setTextSize(2);
} // end void drawThermometer(void)
// draw analog meter background graphics
void analogMeter() {
// meter outline
tft.fillRect(0, 0, meterScaling * 239, meterScaling * 126, GRAY);
tft.fillRect(5, 3, meterScaling * 230, meterScaling * 119, WHITE);
// text color
tft.setTextColor(BLACK);
// draw ticks every 5 degrees from -50 to +50 degrees (100 deg. FSD swing)
// long scale tick length
for (int i = -50; i < 51; i += 5) {
// coordinates of tick to draw
int tl = 15;
float sx = cos((i - 90) * 0.0174532925);
float sy = sin((i - 90) * 0.0174532925);
uint16_t x0 = sx * (meterScaling * 100 + tl) + meterScaling * 120;
uint16_t y0 = sy * (meterScaling * 100 + tl) + meterScaling * 140;
uint16_t x1 = sx * meterScaling * 100 + meterScaling * 120;
uint16_t y1 = sy * meterScaling * 100 + meterScaling * 140;
// coordinates of next tick for zone fill
float sx2 = cos((i + 5 - 90) * 0.0174532925);
float sy2 = sin((i + 5 - 90) * 0.0174532925);
int x2 = sx2 * (meterScaling * 100 + tl) + meterScaling * 120;
int y2 = sy2 * (meterScaling * 100 + tl) + meterScaling * 140;
int x3 = sx2 * meterScaling * 100 + meterScaling * 120;
int y3 = sy2 * meterScaling * 100 + meterScaling * 140;
// green zone limits
if (i >= 0 && i < 25) {
tft.fillTriangle(x0, y0, x1, y1, x2, y2, GREEN);
tft.fillTriangle(x1, y1, x2, y2, x3, y3, GREEN);
// orange zone limits
if (i >= 25 && i < 50) {
tft.fillTriangle(x0, y0, x1, y1, x2, y2, TFT_ORANGE);
tft.fillTriangle(x1, y1, x2, y2, x3, y3, TFT_ORANGE);
// short scale tick length
if (i % 25 != 0) tl = 8;
// recalculate coords incase tick lenght changed
// draw tick
tft.drawLine(x0, y0, x1, y1, BLACK);
// check if labels should be drawn, with position tweaks
if (i % 25 == 0) {
// Calculate label positions
x0 = sx * (meterScaling * 100 + tl + 10) + meterScaling * 120;
y0 = sy * (meterScaling * 100 + tl + 10) + meterScaling * 140;
switch (i / 25) {
// now draw the arc of the scale
sx = cos((i + 5 - 90) * 0.0174532925);
sy = sin((i + 5 - 90) * 0.0174532925);
x0 = sx * meterScaling * 100 + meterScaling * 120;
y0 = sy * meterScaling * 100 + meterScaling * 140;
// draw scale arc, don't draw the last part
if (i < 50) tft.drawLine(x0, y0, x1, y1, BLACK);
// finally - plot scale numbers on the scale
// these numbers are drawn at a fixed location to match
// the meterScaling=1.3333 size. need to make it auto-adjust to any
// meter scaling size
tft.setTextSize(1);
tft.setCursor(35, 80);
tft.println("0");
tft.setCursor(90, 42);
tft.println("25");
tft.setCursor(155, 25);
tft.println("50");
tft.setCursor(220, 38);
tft.println("75");
tft.setCursor(275, 80);
tft.println("100");
// draw bezel line
tft.drawRect(5, 3, meterScaling * 230, meterScaling * 119, BLACK);
} // end void analogMeter()
// needle psoition updater
// this function is blocking while needle moves, time depends on ms_delay
// 10ms minimises needle flicker if text is drawn within needle sweep area
// Smaller values OK if text not in sweep area, zero for instant movement but
// does not look realistic... (note: 100 increments for full scale deflection)
void plotNeedle(int value, byte ms_delay) {
char buf[8]; dtostrf(value, 4, 0, buf);
if (value < -10) value = -10; // Limit value to emulate needle end stops
if (value > 110) value = 110;
// move the needle until new value reached
while (!(value == old_analog)) {
if (old_analog < value) old_analog++;
else old_analog--;
if (ms_delay == 0) old_analog = value; // Update immediately if delay is 0
float sdeg = map(old_analog, -10, 110, -150, -30); // Map value to angle
// calculate tip of needle coords
float sx = cos(sdeg * 0.0174532925);
float sy = sin(sdeg * 0.0174532925);
// calculate x delta of needle start (does not start at pivot point)
float tx = tan((sdeg + 90) * 0.0174532925);
// erase old needle image
tft.drawLine(meterScaling * (120 + 20 * ltx - 1), meterScaling * (140 - 20), osx - 1, osy, WHITE);
tft.drawLine(meterScaling * (120 + 20 * ltx), meterScaling * (140 - 20), osx, osy, WHITE);
tft.drawLine(meterScaling * (120 + 20 * ltx + 1), meterScaling * (140 - 20), osx + 1, osy, WHITE);
// re-plot text under needle
// store new needle end coords for next erase
ltx = tx;
osx = meterScaling * (sx * 98 + 120);
osy = meterScaling * (sy * 98 + 140);
// draw the needle in the new position, magenta makes needle a bit bolder
// draws 3 lines to thicken needle
tft.drawLine(meterScaling * (120 + 20 * ltx - 1), meterScaling * (140 - 20), osx - 1, osy, RED);
tft.drawLine(meterScaling * (120 + 20 * ltx), meterScaling * (140 - 20), osx, osy, MAGENTA);
// try to erase old line
tft.drawLine(meterScaling * (120 + 20 * ltx + 1), meterScaling * (140 - 20), osx + 1, osy, RED);
// slow needle down slightly as it approaches new postion
if (abs(old_analog - value) < 10) ms_delay += ms_delay / 5;
// wait before next update
delay(ms_delay);
} // end plotNeedle
Estoy usando arduino mega y pantalla 3.5" TFT LCD Color Touch Screen Display Module 480x320 Ultra HD ILI9486
