Cambio indirizzo SMBus Melexis MLX90614
Buonasera a tutti, prima di aprire questo post ho cercato risposta in tutti i vecchi post sull’argomento,
sto cercando di cambiare l’indirizzo del bus I2C di questo sensore per poterne usare 6 contemporaneamente.
Sto provando ad usare due sketch ma con entrambi ho degli errori, il primo sketch è:
#include <i2cmaster.h>
// Pins: Standard: SDA:A4  SCL:A5
//       Mega:     SDA:D20 SCL:D21
byte MLXAddr = 0x5A<<1;           // Default address
//byte MLXAddr = 0;               // Universal address
void setup(){
 Serial.println("Setup...");
 i2c_init();                              //Initialise the i2c bus
 PORTC = (1 << PORTC4) | (1 << PORTC5);   //enable pullups
 delay(5000);                    // Wait to allow serial connection
 ReadAddr(0);                    // Read current address bytes
 ChangeAddr(0x55, 0x00);         // Change address to new value
 //ChangeAddr(0x5A, 0xBE);       // Change address to default value
 ReadAddr(0);                    // Read address bytes
 delay(5000);                    // Cycle power to MLX during this pause
 ReadTemp(0);                    // Read temperature using default address
 ReadTemp(MLXAddr);              // Read temperature using new address
void loop(){
   delay(1000); // wait a second
word ChangeAddr(byte NewAddr1, byte NewAddr2) {
 Serial.println("> Change address");
 i2c_start_wait(0 + I2C_WRITE);    //send start condition and write bit
 i2c_write(0x2E);                  //send command for device to return address
 i2c_write(0x00);                  // send low byte zero to erase
 i2c_write(0x00);                  //send high byte zero to erase
 if (i2c_write(0x6F) == 0) {
   i2c_stop();                     //Release bus, end transaction
   Serial.println("  Data erased.");
 else {
   Serial.println("  Failed to erase data");
   return -1;
 Serial.print("  Writing data: ");
 Serial.print(NewAddr1, HEX);
 Serial.print(", ");
 Serial.println(NewAddr2, HEX);
 for (int a = 0; a != 256; a++) {
   i2c_write(NewAddr1);            // send low byte zero to erase
   i2c_write(NewAddr2);            //send high byte zero to erase
   if (i2c_write(a) == 0) {
     delay(100);                   // then wait 10ms
     Serial.print("Found correct CRC: 0x");
     Serial.println(a, HEX);
     return a;
 Serial.println("Correct CRC not found");
 return -1;
void ReadAddr(byte Address) {
 Serial.println("> Read address");
 Serial.print("  MLX address: ");
 Serial.print(Address, HEX);
 Serial.print(", Data: ");
 i2c_start_wait(Address + I2C_WRITE);  //send start condition and write bit
 i2c_rep_start(Address + I2C_READ);
 Serial.print(i2c_readAck(), HEX); //Read 1 byte and then send ack
 Serial.print(", ");
 Serial.print(", ");
 Serial.println(i2c_readNak(), HEX);
 i2c_stop();
float ReadTemp(byte Address) {
 int data_low = 0;
 int data_high = 0;
 int pec = 0;
 Serial.println("> Read temperature");
 Serial.print(", ");
 i2c_write(0x07);                  // Address of temp bytes
 // read
 data_low = i2c_readAck();         //Read 1 byte and then send ack
 data_high = i2c_readAck();        //Read 1 byte and then send ack
 pec = i2c_readNak();
 i2c_stop();
 //This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
 float Temperature = 0x0000;       // zero out the data
 // This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
 Temperature = (float)(((data_high & 0x007F) << 8) + data_low);
 Temperature = (Temperature * 0.02) - 273.16;
 Serial.print(Temperature);
 Serial.println(" C");
 return Temperature;
in allegato gli errori che mi escono in fase di compilazione.
il post da cui ho preso spunto è questo
in cui si parla del CRC ma va oltre le mie conoscenze ed avrei bisogno di qualcuno che me lo spiegasse
Grazie mille
errori1.txt (4.39 KB)
ed il secondo
//byte MLXAddr = 0x5A<<1;           // Default address
  byte MLXAddr = 0x0A<<1;           // New Address: Change this value to wathever you want the new adress of the MLX to be.
void setup(){
  i2c_init();                                // Initialise the i2c bus
  //PORTC = (1 << PORTC4) | (1 << PORTC5);   // Enable pullups resistors (uncomment for std arduinos)
  PORTD = (1 << PORTD1) | (1 << PORTD0);     // Enable pullups resistors (uncomment for arduino MEGA)
  ChangeAddr(MLXAddr>>1, 0x00);   // Change address to new value
  Serial.println("Manually cycle power the MLX, you have 10 seconds.");
  delay(10000);                    // Cycle power to MLX during this pause
  Serial.println("Cycle power delay expired.");
  delay(2000);                     // Additionnal delay buffer
  Serial.println("Testing temperature reading on universal address.");
  Serial.println("Testing temperature reading on new address.");
  Serial.println("Done");
void loop(){
  else {
    return -1;
  Serial.print(", ");
      return a;
  return -1;
  Serial.print(", ");
  Serial.print(", ");
  i2c_stop();
  int data_low = 0;
  int data_high = 0;
  int pec = 0;
  Serial.print(", ");
  // read
  i2c_stop();
  return Temperature;
errori2.txt (4.39 KB)
Ancora una volta ti richiamo al rispetto del regolamento e ti ricordo che in conformità al suddetto REGOLAMENTO, punto 13, il cross-posting è proibito ([u]anche tra lingue diverse[/u]) e tu hai chiesto in merito allo stesso argomento (I2C master) in un altro thread di lingua Inglese.
Il tuo post è stato quindi cancellato e ... attenzione ... !
Guglielmo
Ok, scusa ma non avendo ricevuto risposta ed avendo scritto in un post molto vecchio ne ho aperto un altro... Certo che non me ne lasci passare una :confused:
scoprire: ... Certo che non me ne lasci passare una :confused:
... manco mezza, però ... [u]NON[/u] in particolare a te, ma [u]in generale[/u] ... come avrai visto se segui il forum ! :stuck_out_tongue_closed_eyes: :stuck_out_tongue_closed_eyes: :stuck_out_tongue_closed_eyes:
Guglielmo
