Camera and temp controllin relay
Hi maybe someone can help me. I want to control a relay when (camera && temperature) are true... relay is turns on. When both are true but I can't get the code right. I'm using a DHT11 temp sensor and processing for camera.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
We cannot give you advise until we see your code.
Thanks .. Tom... :slight_smile:
sorry my bad…
#include <dht.h>
int greenPin = 6;
int redPin = 5;
int bluePin = 9;
int relayPin = 7:
dht DHT;
void setup(){
    pinMode(bluePin, OUTPUT);    //initialize LED output
  if(Serial.available() >0)    //if some data is available of in the serial port
    char bluePinState = Serial.read();   //read the value
    if(bluePinState == '1')
                 //if statement will be true(1)
      digitalWrite(relayPin, HIGH);       //turn ON the LED
    if(bluePinState == '0')
                 //if statement will be false(0)
      digitalWrite(relayPin, LOW);        //turn OFF the LED
 if (DHT.temperature <= 24 )
    digitalWrite(bluePin, LOW);
   digitalWrite(bluePin, HIGH);
   delay(5000);
Can you get the relay to operate using serial?
Tom… :slight_smile:
int relayPin = 7:
should be
int relayPin = 7;
a ; instead of a :
Easily done, see if that fixes it.
Tom.... :slight_smile:
I can get serial to operate the relay but what ends up happening is the serial seems to override the temperature no matter what. negating the function.
Hi, I cleaned up the code a bunch but camera still seems to trigger the relay no matter the state of the temperature.
#include <dht.h>
int airtempPin = 6;    //temperature of the air
int coiltempPin = 5;  // temperature of the heating coil
int relayPin = 7;     // turns on by camera and air temperature
int bluePinState;
dht DHT;              // needed for temperature
    Serial.begin(9600);                   // start serial at 9600
        pinMode(relayPin, OUTPUT);        //initialize relay output
void loop(){
  int chk = DHT.read11(airtempPin);            // checks the air temperature of airtempPin
  delay(2000);
           if(bluePinState == '1' && DHT.temperature <=18)      //if statement will be true(1)
              digitalWrite(relayPin, HIGH);                     //turn ON the relay
           if(bluePinState == '0')                              //if statement will be false(0)
              digitalWrite(relayPin, LOW);                      //turn OFF the relay
How do you know? I'd try displaying the temperature you're reading from the sensor on the serial port to start the debugging process.
I changed temp from >= 18C to <=17C and it didn’t change the state of the relay. in this statement <=17 and air temp is above 18C it would make the statement false. but if i set the trigger to be >=18C and air temp is above this should make statement true thus triggering the relay???
I ASSUME that the serial input is the camera input?
I don’t know if this is exactly what you want.
#include <dht.h>
char bluePinState = "0";
int airTemperature;
bool airTLow;
  airTemperature = DHT.read11(airtempPin);            // checks the air temperature of airtempPin
  delay(2000);
  if (airTemperature <= 18)                           // checks if air temp is in range
    airTLow = 1;
    airTLow = 0;
  if (Serial.available() > 0)                          //if some data is available of in the serial port
  if (airTLow == 1 && bluePinState == "1")             // checks for both condition to be true
First read ALL your inputs
Then compare them to produce your output.
Tom… :slight_smile:
thanks i'll give that code a go and let you know of my results.
the code worked pretty good thanks… i would have never have thought of doing
if (airTemperature <= 24)                           // checks if air temp is in range
    airTLow = 1;
    airTLow = 0;
i was wondering if there was a way to assign a 1 or 0 to a temperature…
