hi,this is first time i use arduino.
i use Grove Serial Camera Kit and mega2560 and Ethernet W5100 SD shield,
i copy this code:Grove_Serial_Camera_Kit/SerialCameral_DemoCode_CJ_OV528_SoftSer.ino at master · Seeed-Studio/Grove_Serial_Camera_Kit · GitHub
circuit:
GND---GND
RX---D3
TX---D2
5V---5V
unfortunately,it always stay at "initializing camera............................."
i search a lot ,somebody say problem maybe is Serial Communication,RS232 and TTL.
i also try max232,but that also useless.
You really should read the documentation for the SoftwareSerial library. A big fat clue by four will smack you.
You really ought to think about why you are using SoftwareSerial when you have 3 unused hardware serial ports.
Thanks for your help,
but i still understand,
Do you mean the limitations
On Arduino or Genuino 101 the current maximum RX speed is 57600bps?
i change bps but it still useless,
SoftwareSerial softSerial(14, 15);<--i use mega2560,so i change RX TX pins.
#define CAM_ADDR 0
unsigned long picTotalLen = 0; // picture length
should i change?
i search a lot,but i still understand what problem.
The point is, why use SoftSerial at all when you have 4 hardware serial ports available ?
Even more pointed, why are you trying to use pins that belong to one of the hardware serial ports with the SoftSerial library ?
can you send full programe for UNO?
thanojan:
A full program to do what? How much are you willing to pay?
UKHeliBob:
SoftwareSerial softSerial(14, 15);<--i use mega2560,so i change RX TX pins.The point is, why use SoftSerial at all when you have 4 hardware serial ports available ?
oh,i think it must connect RX TX on arduino.
Do you mean when i use softserial library,i can ignore RX TX on arduino?
but i look softserial library,it seems having some limitations.
sorry i don't understand softserial library.
thanks
I am saying don't use SoftwareSerial at all. The Mega has 4 hardware serial ports so use one of them instead.
UKHeliBob:
thank you!!
i try each serial,
but it still can't initialize
i try each serial,
Please post the code you tried and details of the pins used. Did you remember to use Serial1.begin() etc when you tried ?
#include <Arduino.h>
#include <SD.h>
#include <SPI.h>
#define PIC_PKT_LEN 128 //data length of each read, dont set this too big because ram is limited
#define PIC_FMT_VGA 7
#define PIC_FMT_CIF 5
#define PIC_FMT_OCIF 3
#define CAM_ADDR 0
#define CAM_SERIAL Serial1
#define PIC_FMT PIC_FMT_VGA
File myFile;
const int rxPin = 18;
const int txPin = 19;
const byte cameraAddr = (CAM_ADDR << 5); // addr
const int buttonPin = 5; // the number of the pushbutton pin
int picNameNum = 0;
CAM_SERIAL.begin(9600); //cant be faster than 9600, maybe difference with diff board.
pinMode(buttonPin, INPUT); // initialize the pushbutton pin as an input
Serial.println("Initializing SD card....");
pinMode(4,OUTPUT); // CS pin of SD Card Shield
if (!SD.begin(4)) {
Serial.print("sd init failed");
return;
Serial.println("sd init done.");
initialize();
int n = 0;
while(1){
Serial.println("\r\nPress the button to take a picture");
while (digitalRead(buttonPin) == LOW); //wait for buttonPin status to HIGH
Serial.println("taking");
if(digitalRead(buttonPin) == HIGH){
delay(20); //Debounce
if (digitalRead(buttonPin) == HIGH)
delay(200);
if (n == 0) preCapture();
Capture();
Serial.print("Saving picture...");
GetData();
Serial.print("\r\nDone ,number : ");
Serial.println(n);
n++ ;
void clearRxBuf()
while (CAM_SERIAL.available())
CAM_SERIAL.read();
void sendCmd(char cmd[], int cmd_len)
for (int i = 0; i < cmd_len; i++) CAM_SERIAL.write(cmd[i]);
int readBytes(char *dest, int len, unsigned int timeout)
int read_len = 0;
unsigned long t = millis();
while (read_len < len)
while (CAM_SERIAL.available()<1)
if ((millis() - t) > timeout)
return read_len;
*(dest+read_len) = CAM_SERIAL.read();
Serial.write(*(dest+read_len));
read_len++;
return read_len;
void initialize()
char cmd[] = {0xaa,0x0d|cameraAddr,0x00,0x00,0x00,0x00} ;
unsigned char resp[6];
Serial.print("initializing camera...");
while (1)
sendCmd(cmd,6);
if (readBytes((char *)resp, 6,1000) != 6)
Serial.print(".");
continue;
if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x0d && resp[4] == 0 && resp[5] == 0)
if (readBytes((char *)resp, 6,500) != 6) continue;
if (resp[0] == 0xaa && resp[1] == (0x0d | cameraAddr) && resp[2] == 0 && resp[3] == 0 && resp[4] == 0 && resp[5] == 0) break;
cmd[1] = 0x0e | cameraAddr;
cmd[2] = 0x0d;
sendCmd(cmd, 6);
Serial.println("\nCamera initialization done.");
void preCapture()
char cmd[] = { 0xaa, 0x01 | cameraAddr, 0x00, 0x07, 0x00, PIC_FMT };
while (1)
clearRxBuf();
sendCmd(cmd, 6);
if (readBytes((char *)resp, 6, 100) != 6) continue;
if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x01 && resp[4] == 0 && resp[5] == 0) break;
void Capture()
char cmd[] = { 0xaa, 0x06 | cameraAddr, 0x08, PIC_PKT_LEN & 0xff, (PIC_PKT_LEN>>8) & 0xff ,0};
while (1)
clearRxBuf();
sendCmd(cmd, 6);
if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x06 && resp[4] == 0 && resp[5] == 0) break;
cmd[1] = 0x05 | cameraAddr;
cmd[2] = 0;
cmd[3] = 0;
cmd[4] = 0;
cmd[5] = 0;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x05 && resp[4] == 0 && resp[5] == 0) break;
cmd[1] = 0x04 | cameraAddr;
cmd[2] = 0x1;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x04 && resp[4] == 0 && resp[5] == 0)
if (readBytes((char *)resp, 6, 1000) != 6)
continue;
if (resp[0] == 0xaa && resp[1] == (0x0a | cameraAddr) && resp[2] == 0x01)
picTotalLen = (resp[3]) | (resp[4] << 8) | (resp[5] << 16);
Serial.print("picTotalLen:");
Serial.println(picTotalLen);
void GetData()
unsigned int pktCnt = (picTotalLen) / (PIC_PKT_LEN - 6);
if ((picTotalLen % (PIC_PKT_LEN-6)) != 0) pktCnt += 1;
char cmd[] = { 0xaa, 0x0e | cameraAddr, 0x00, 0x00, 0x00, 0x00 };
unsigned char pkt[PIC_PKT_LEN];
char picName[] = "pic00.jpg";
picName[3] = picNameNum/10 + '0';
picName[4] = picNameNum%10 + '0';
if (SD.exists(picName))
SD.remove(picName);
myFile = SD.open(picName, FILE_WRITE);
if(!myFile){
Serial.println("myFile open fail...");
else{
for (unsigned int i = 0; i < pktCnt; i++)
cmd[4] = i & 0xff;
cmd[5] = (i >> 8) & 0xff;
int retry_cnt = 0;
retry:
delay(10);
clearRxBuf();
sendCmd(cmd, 6);
uint16_t cnt = readBytes((char *)pkt, PIC_PKT_LEN, 200);
unsigned char sum = 0;
for (int y = 0; y < cnt - 2; y++)
sum += pkt[y];
if (sum != pkt[cnt-2])
if (++retry_cnt < 100) goto retry;
else break;
myFile.write((const uint8_t *)&pkt[4], cnt-6);
//if (cnt != PIC_PKT_LEN) break;
cmd[4] = 0xf0;
cmd[5] = 0xf0;
sendCmd(cmd, 6);
myFile.close();
picNameNum ++;
sorry,i don't completely understand this code.
i just revise a little.
thank you!!
When you used the code you posted which pins was the camera connected to and are you sure that you connected Arduino Tx to camera Rx and Arduino Rx to camera Tx ?
You have still not said which Arduino pins you used when using Serial1 and whether you are sure that the Rx/Tx pairs were connected correctly.
oh,sorry.
TX-TTL conect pin 18,RX-TTL conect pin 19,
thank you.
The way that I read that you have TTL Tx connected to Arduino pin 18 (Serial1 Tx) and TTL Rx connected to Arduino pin 19 (Serial1 Rx)
If that is what you have done then you have the connections the wrong way round. Tx on one device should go to Rx on the other and vice versa
http://www.seeedstudio.com/depot/Grove-Serial-Camera-p-945.html
This is my camera i want wiring with Arduino Uno and programme for when press the button camera will take a picture. Pls help me.
thank for read.
i reference this code
#include <SPI.h>
#include <arduino.h>
#include <SD.h>
#define CAM_ADDR 0
File myFile;
const int buttonPin = 9; // the number of the pushbutton pin
int picNameNum = 0;
if (!SD.begin(4))
return;
initialize();
int n = 0;
while(1){
Serial.println("\r\nbegin to take picture");
delay(200);
Capture();
GetData();
Serial.print("\r\nTaking pictures success ,number : ");
Serial.println(n);
n++ ;
void clearRxBuf()
while (Serial.available())
Serial.read();
for (char i = 0; i < cmd_len; i++) Serial.print(cmd[i]);
void initialize()
Serial.setTimeout(500);
while (1)
//clearRxBuf();
sendCmd(cmd,6);
if (Serial.readBytes((char *)resp, 6) != 6)
continue;
if (Serial.readBytes((char *)resp, 6) != 6) continue;
cmd[2] = 0x0d;
sendCmd(cmd, 6);
void preCapture()
Serial.setTimeout(100);
while (1)
clearRxBuf();
sendCmd(cmd, 6);
void Capture()
while (1)
clearRxBuf();
sendCmd(cmd, 6);
cmd[2] = 0;
cmd[3] = 0;
cmd[4] = 0;
cmd[5] = 0;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
cmd[2] = 0x1;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
Serial.setTimeout(1000);
continue;
void GetData()
SD.remove(picName);
if(!myFile){
else{
cmd[4] = i & 0xff;
int retry_cnt = 0;
retry:
delay(10);
clearRxBuf();
sendCmd(cmd, 6);
uint16_t cnt = Serial.readBytes((char *)pkt, PIC_PKT_LEN);
sum += pkt[y];
else break;
cmd[4] = 0xf0;
cmd[5] = 0xf0;
sendCmd(cmd, 6);
myFile.close();
picNameNum ++;
it work!!
but i don't know why i use another serial always fail.
i use mega2560 and W5100 SD sheid
thanks for your help!!!
UKHeliBob:
The way that I read that you have TTL Tx connected to Arduino pin 18 (Serial1 Tx) and TTL Rx connected to Arduino pin 19 (Serial1 Rx)If that is what you have done then you have the connections the wrong way round. Tx on one device should go to Rx on the other and vice versa
oh, thank you.but i think the circuit of MAX232 is same as the connections what you say.
finally,i didn't use MAX232,and i reference another code(it use serial),it work
i want to use serial2
#include <SD.h>
#include <SPI.h>
#define CAM_ADDR 0
#define CAM_SERIAL Serial2
File myFile;
const int RXPIN = 17;
const int TXPIN = 16;
int picNameNum = 0;
if (!SD.begin(4)) {
return;
initialize();
int n = 0;
while(1){
delay(200);
Capture();
GetData();
Serial.println(n);
n++ ;
void clearRxBuf()
CAM_SERIAL.read();
for (char i = 0; i < cmd_len; i++){ CAM_SERIAL.write(cmd[i]);
void initialize()
Serial2.setTimeout(500);
while (1)
sendCmd(cmd,6);
if (Serial2.readBytes((char *)resp, 6) != 6)
Serial.print(".");
continue;
if (Serial2.readBytes((char *)resp, 6) != 6) continue;
cmd[2] = 0x0d;
sendCmd(cmd, 6);
void preCapture()
Serial2.setTimeout(100);
while (1)
clearRxBuf();
sendCmd(cmd, 6);
void Capture()
while (1)
clearRxBuf();
sendCmd(cmd, 6);
cmd[2] = 0;
cmd[3] = 0;
cmd[4] = 0;
cmd[5] = 0;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
cmd[2] = 0x1;
while (1)
clearRxBuf();
sendCmd(cmd, 6);
Serial2.setTimeout(1000);
continue;
void GetData()
SD.remove(picName);
if(!myFile){
else{
cmd[4] = i & 0xff;
int retry_cnt = 0;
retry:
delay(10);
clearRxBuf();
sendCmd(cmd, 6);
uint16_t cnt = Serial2.readBytes((char *)pkt, PIC_PKT_LEN);
sum += pkt[y];
else break;
cmd[4] = 0xf0;
cmd[5] = 0xf0;
sendCmd(cmd, 6);
myFile.close();
picNameNum ++;
it can run,but didn't save image into SD card.
Is it work with Arduino Uno?
How to wire with Arduino Uno?
