Camera Slider Controller Issues - Need Help
I am trying to setup the camera slider controller using the guide by youtuber Novaspirit Tech
The hardware includes NEMA 17 step motor, ESP8266 and TMC2100. Attached is the diagram of the setup which
is controlled by wifi access to the device, there are 4 speed options, but no matter
which one i select the speed does not change.
Also the motor turns but pauses every few seconds unexpectedly, it should keep turning
for the equivalent of 2feet,
The code for running this setup is from
I really need some help. i've spent over 3 days trying to get this to work.
Any help would be greatly appreciated.
Camera Slider Code.txt (4.35 KB)
Image from Original Post so we don't have to download it. See this Simple Image Guide
And the code
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char* ssid = "Slider";
const char* password = "password";
ESP8266WebServer server(80);
int x;
const int enable = 16; /*D0*/
const int stepping = 2; /*D4*/
const int dir = 0; /*D3*/
const int m3 = 5; /*D1*/
const int m2 = 4; /*D2*/
const int m1 = 14; /*D5*/
const int StepperSpeed = 1;
const int sliderWidth = 6200; //2' slider
int direct = 1;
int sliderWidthMulti = 0;
String webPage = "<html> <head> <style> button {   background-color: #4CAF50;  padding: 12px 28px;   width: 100%;  height: 20%;  border-radius: 8px;   border: 0px;  font-size: 16px;  color: white;   } h1 {  text-align: center;   }  </style> </head> <body> <h1>Novaspirit Slider v1</h1> <p><button onmousedown=location.href=\"/normal\">nornmal</button></p> <p><button onmousedown=location.href=\"/slow\">slow</button></p> <p><button onmousedown=location.href=\"/slower\">slower</button></p> <p><button onmousedown=location.href=\"/slowest\">slowest</button></p> </body> </html>";
void handleRoot() {
  server.send(200, "text/html", webPage);
void handleNotFound(){
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
void setup(void){
  pinMode(enable, OUTPUT);
  pinMode(stepping, OUTPUT);
  pinMode(dir, OUTPUT);
  pinMode(m3, OUTPUT);
  pinMode(m2, OUTPUT);
  pinMode(m1, OUTPUT);
  digitalWrite(enable, 0);
  WiFi.softAP(ssid, password);
  IPAddress apip = WiFi.softAPIP();
  Serial.println("apip");
  /* Wait for connection
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  if (MDNS.begin("esp8266")) {
    Serial.println("MDNS responder started");
  server.on("/", handleRoot);
  server.on("/normal", [](){
    if (direct == 0)
      digitalWrite(dir, 1);
      direct = 1;
    }else
      digitalWrite(dir, 0);
      direct = 0;
    digitalWrite(m1, 1);
    digitalWrite(m2, 0);
    digitalWrite(m3, 0);
    for(x=0; x < sliderWidth; x++){
      digitalWrite(stepping, 1);
      digitalWrite(stepping, 0);
      delay(StepperSpeed);
  server.on("/slow", [](){
    if (direct == 0)
      direct = 1;
    }else
      direct = 0;
    digitalWrite(m1, 0);
    digitalWrite(m2, 1);
    sliderWidthMulti = sliderWidth * 2;
    for(x=0; x < sliderWidthMulti; x++){
  server.on("/slower", [](){
        if (direct == 0)
      direct = 1;
    }else
      direct = 0;
    sliderWidthMulti = sliderWidth * 4;
  server.on("/slowest", [](){
    if (direct == 0)
      direct = 1;
    }else
      direct = 0;
    digitalWrite(m3, 1);
    sliderWidthMulti = sliderWidth * 8;
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("HTTP server started");
void loop(void){
  server.handleClient();
...R
I hope you are not really powering it with one of those PP3 style batteries?
...R
In the program the variable StepperSpeed seems to control the speed but it never changes
The distance the motor moves (the number of steps) seems to be set with the lines like this
and that distance changes depending on the WiFi input.
It seems to me whoever wrote the program got the distance and speed mixed up.
...R
Stepper Motor Basics
Simple Stepper Code
The TMC2100 is powered by 12v mains adapter
The ESP8866 is connected to usb on my PC
I need someone to help me with correcting and emsuring the config works as expected, i dont mind paying a little towards getting a config that works. can anyone recommend who i can contact?
bobster316:
If you just want someone to write a program for you please ask in the Gigs and Collaborations section of the Forum and be prepared to pay.
You will still have to do the "ensuring" as you are the person with the hardware.
...R
Thanks will have a look
bobster316's post in the Gigs and Collaborations section:
https://forum.arduino.cc/index.php?topic=614125
