I’m working on a motion activated (PIR) camera arducam that stores to SD card. So far so good. I recently ran across an example where someone used an EyeFi card to transfer files over wifi as they came in. I was able to modify my code to write to a subdirectory that could be read (DCIM/Cameraname/img_XXX.jpg)by the eyefi. It seems to work, but this is where I ran into some trouble. When I run the sketch is captures sometimes 1 image or 2 or even three, but then it snags, stops processing and/or starts to output junk text to the serial monitor.
I’m kind of guessing there’s a processing speed hiccup going on and I’ve tried to insert some delays in various points as a random stab at giving the processor some time to deal with each piece, but no luck. Wondering if anyone is interested in looking at my code and offering some suggestions.
In terms of hardware, I’m using an Arducam mini, an Arduino Uno and an adafruit datalogging shield for sd storage. I’m pasting a portion of the loop code where the camera is activated and captures images.
char str[8];
File outFile;
byte buf[256];
static int i = 0;
static int k = 0;
static int n = 0;
uint8_t temp, temp_last;
uint8_t start_capture = 0;
int total_time = 0;
if (digitalRead(pirPin) == HIGH) //If a motion is detected
digitalWrite(ledPin, HIGH); //signal that a motion is detectedstate
digitalWrite(irPin, HIGH); //turn on IR LEDs
if (lockLow)
lockLow = false; // We enter in "motion" mode
Serial.println("---"); //record and display start time of motion detection
Serial.print("motion detected at ");
Serial.print(millis() / 1000);
Serial.println(" sec");
start_capture = 1;
delay(100);
//Camera capture general
if (start_capture)
myCAM.flush_fifo(); //Flush the FIFO
myCAM.clear_fifo_flag(); //Clear the capture done flag
myCAM.start_capture(); //Start capture
Serial.println("Start Capture");
while (!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK));
Serial.println("Capture Done!");
char filename[26]; //Construct a file name
for (int i = 0; i < 1000; i++) {
sprintf(filename, "DCIM/CANON999/IMG_%03d.JPG", i);
if (! SD.exists(filename)) { // create if does not exist, do not open existing, write, sync after write
outFile = SD.open(filename, O_WRITE | O_CREAT | O_TRUNC); //Open the new file
if (! outFile)
Serial.println("open file failed");
return;
total_time = millis();
i = 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
temp = SPI.transfer(0x00);
while ( (temp != 0xD9) | (temp_last != 0xFF)) //Read JPEG data from FIFO
temp_last = temp;
if (i < 256) //Write image data to buffer if not full
buf[i++] = temp;
myCAM.CS_HIGH(); //Write 256 bytes image data to file
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
if (i > 0) //Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
outFile.close(); //Close the file
total_time = millis() - total_time;
Serial.print("Total time used:");
Serial.print(total_time, DEC);
Serial.println(" millisecond"); //Clear the capture done flag
start_capture = 0; //Clear the start capture flag
delay(200);
lastshot = millis();
burst = true; //Now we go in burst mode,ie picture will be taken every 5S
if (burst) //Once the motion has been detected and a picture taken, we go into this mode to keep taking pictures every 5s until the motion ends
delay (burstInterval);
start_capture = 1;
delay(100);
PIR_Arducam4_burst_IR_eyefi.ino (13.7 KB)
