I am doing an Arduino project where I have 1 Arduino UNO acting as a Master device in a SPI protocol, and another Arduino thats supposed to act as 2 slave devices. Yes I know I can use 2 Arduino's each being a slave, but i am hoping to avoid that. The slave Arduino is simulating 2 Hbridges and its basically acting as 2 instances of the same exact device, thats why I was hoping one Arduino can simulate both Hbridges simultaneously.
I tried using an arbitrary digital IO pin as a second Slave Select and using the predefined pin 10 as the first slave device, but SPI does not activate when bringing down the Arbitrary Slave Pin.
My Master and Slave code is below.
/************************************************MASTER TEST FILE******************************/
#include <SPI.h>
#define MSBmessage 0x50
#define MIDmessage 0x00
#define LSBmessage 0x00
#define SS2 9
int del= 0;
byte b[3];
unsigned long message = 0;
/************************************************* Slave Receive Function **********************************************/
byte SPI_MasterReceive(void)
/* Wait for reception complete */
while(!(SPSR & (1<<SPIF)))
/* Return Data Register */
Serial.print("RX: ");
Serial.print(SPDR,HEX);
Serial.print('\n');
return SPDR;
/************************************************ Slave Transmit Function ********************************************/
void SPI_MasterTransmit(byte cData)
Serial.print("TX: ");
Serial.print(cData, HEX); //debug to monitor master transmit
Serial.print('\n');
SPDR = cData;
while (!(SPSR & (1 << SPIF)));
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV128);
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
pinMode(MISO, INPUT);
pinMode(SS, OUTPUT);
pinMode(SS2, INPUT);
digitalWrite(SS, HIGH);
digitalWrite(SS2, HIGH);
digitalWrite(SS2, LOW); //TURN SPI TRANSFER ON
//SPI.transfer(0x50); //0x50 (Command)
/******************************************************* First byte transmit/recieve *******************************************************/
SPI_MasterTransmit(MSBmessage); //0x50 Status Byte
delay(del);
b[2] = SPI_MasterReceive(); //First response byte
// Serial.print("b[2]: ");
// Serial.print(b[2], HEX); //debug to monitor master receive
// Serial.print('\n');
/******************************************************* Second byte transmit/recieve *******************************************************/
SPI_MasterTransmit(MIDmessage); //0x00 Status Byte
delay(del);
b[1] = SPI_MasterReceive(); //Second response byte
// Serial.print("b[1]: ");
// Serial.print(b[1], HEX); //debug to monitor master receive
/******************************************************* Third byte transmit/recieve *******************************************************/
SPI_MasterTransmit(LSBmessage); //0x00 Status Byte
delay(del);
b[0] = SPI_MasterReceive(); //Third response byte
digitalWrite(SS2, HIGH); //TURN SPI TRANSFER OFF
Slave Code
//#define SERIAL_DEBUG_OFF
#define SS2 9
volatile byte message;
uint8_t message_State = 0;
int messageCounter = 0;
long int myMessages[9] = {0x654321, 0x123456, 0x030000, 0x042000, 0x050100, 0x060080, 0x070040, 0x080008, 0x090004}; //TEST MESSAGES
//long int myMessages[9] = {0x000000, 0x400000, 0x100000, 0x002000, 0x000100, 0x000080, 0x000040, 0x000008, 0x000004}; //REAL MESSAGES
byte TX_buffer_Glass[3];
byte TX_buffer_Shade[3];
volatile byte TX_buffer[3];
byte SPI_SlaveReceive(void)
#ifndef SERIAL_DEBUG_OFF
Serial.print(SPDR, HEX);
Serial.print('\n');
#endif
return SPDR;
void SPI_SlaveTransmit(byte cData)
Serial.print(cData, HEX); //Slave Transmit debug monitor
Serial.print('\n');
#endif
SPDR = cData;
/************************************************ SPI_Handler Function ********************************************/
void SPI_Handler(byte TX_buffer[])
message = SPI_SlaveReceive();
if ((message == MSBmessage) && (message_State == 0))
SPI_SlaveTransmit(TX_buffer[0]);
message_State = 1;
else if ((message == MIDmessage) && (message_State == 1))
SPI_SlaveTransmit(TX_buffer[1]);
message_State = 2;
else if ((message == LSBmessage) && (message_State == 2))
SPI_SlaveTransmit(TX_buffer[2]);
message_State = 0;
message_State = 0;
/************************************************ SPI_TXmessageParsing Function ********************************************/
void SPI_TXmessageParsing(long faultMessage)
TX_buffer[0] = (faultMessage >> 16); //MSB
TX_buffer[1] = (faultMessage >> 8);
TX_buffer[2] = (faultMessage); //LSB
#endif
pinMode(MISO, OUTPUT);
pinMode(SS, INPUT);
SPCR |= _BV(SPE); //turn on SPI in slave mode
SPI_TXmessageParsing(myMessages[0]); //654321
memcpy(TX_buffer_Glass, TX_buffer, sizeof(TX_buffer));
SPI_TXmessageParsing(myMessages[1]); //123456
memcpy(TX_buffer_Shade, TX_buffer, sizeof(TX_buffer));
//spi sending happens here
if (digitalRead (SS) == LOW)
SPI_Handler(TX_buffer_Glass);
// do nothing
if (digitalRead (SS2) == LOW)
SPI_Handler(TX_buffer_Shade);
// do nothing
Blockquote
