CAN 29bits for ARDUINO UNO/2560 solved
This software works with CAN shield (int 2) on Arduino UNO/Mega2560. Need FreeRTOS.
Receive CAN frames and send them via serial.
CAN 250 Kbps
Serial 9600 bps
// CAN Read
// oceam2@yahoo.com
// V 1.0
#if defined ARDUINO_SAM_DUE
#include <FreeRTOS_ARM.h>
#else
#include <FreeRTOS_AVR.h>
#endif
#include <SPI.h>
#include "mcp_can_j1939_v2.h"
#include "can_ext_j1939_v2.h"
#define Int_Can 2
//Asignaciones
QueueHandle_t xQueue1;
//Variables
TaskHandle_t xHandle_1;
struct AMessage {
  byte nPriority;
  byte nSrcAddr;
  byte nDestAddr;
  byte nData[8];
  int nDataLen;
  long lPGN;
  long time;
  uint32_t cuenta;
} xMessage, *pxMessage, *pxRxedMessage;
struct trama_can {
  //EEC2
  uint16_t Accelerator_Pedal_Position_1;
  uint16_t Engine_Percent_Load_At_Current_Speed;
  //IC1
  uint16_t Engine_Intake_Manifold_1_Pressure;
  uint16_t Engine_Intake_Manifold_1_Temperature;
  //EEC1
  uint16_t pressure_measurement_air_intake_manifold;
  uint16_t Drivers_Demand_Engine_requested;
  uint16_t actual_engine_calculated_torque;
  uint16_t engine_demand_requested_torque;
  uint16_t engine_speed_rpm;
  uint16_t engine_speed_rpm2;
  //VEP1
  float Vehicle_Electrical_Power;
  //ET1
  uint16_t Engine_Coolant_Temperature;
  //EFL_P2
  uint16_t Fan_Drive_State;
  uint16_t Estimated_Percent_Fan_Speed;
  //AMB
  uint16_t Barometric_Pressure_Absolute;
  //EFL_P1
  uint16_t Engine_Fuel_Delivery_Pressure;
  uint16_t Engine_Oil_Pressure;
  //Fuel
  uint16_t Fuel_Level;
} can_mega2560;
  // initialize SPI:
  SPI.begin();
  //Serial
  // Creamos la cola CAN
  xQueue1 = xQueueCreate(100, sizeof(struct AMessage *));
  if (xQueue1 == NULL) Serial.println("Queue Fail !"); else Serial.println("Queue Created OK.");
  canInitialize(10); // 11=250k @8MHz 10=250K @16MHz
  //FreeRTOS
  if (xTaskCreate(vPeriodicTask1, "CAN_RX", 300, NULL, tskIDLE_PRIORITY + 1, &xHandle_1) == pdPASS) { NULL; }
  // INT Cola CAN
  attachInterrupt(digitalPinToInterrupt(Int_Can), recibir_can, FALLING);   //Can
  vTaskStartScheduler();
  for (;;);
// Tarea 1
void vPeriodicTask1(void *pvParameters)
  static char sString[80];
  TickType_t xLastWakeTime = xTaskGetTickCount();
  for (;;)
    // Lectura cola CAN RX
    if (xQueue1 != 0)
      // Receive a message on the created queue.  Block for 10 ticks if a message is not immediately available
      if (xQueueReceive(xQueue1, &(pxRxedMessage), (TickType_t)10))
        long lMessageID2 = ((long)pxRxedMessage->nPriority << 26) + ((long)pxRxedMessage->lPGN << 8) + (long)pxRxedMessage->nSrcAddr;
        switch (lMessageID2)
        case 0x18FEF803: {
        //  can_mega2560.temperatura_transmision = (uint16_t)(0.03125* (pxRxedMessage->nData[4] + 256 * pxRxedMessage->nData[5]) - 273);
          break;       }
        case 0x18F00200: {
          can_mega2560.engine_speed_rpm = (pxRxedMessage->nData[5] + 256 * pxRxedMessage->nData[6]);
          break;       }
        default:
        ltoa(lMessageID2, sString, 16);
        strupr(sString);
        Serial.print("ID:");
        Serial.print(sString);
        Serial.print(" ");
        sprintf(sString, "PGN:%05u P:%X S:%X D:%X ", (int)pxRxedMessage->lPGN, pxRxedMessage->nPriority, pxRxedMessage->nSrcAddr, pxRxedMessage->nDestAddr);
        Serial.print("Data:");
        for (int nIndex = 0; nIndex < pxRxedMessage->nDataLen; nIndex++)
        sprintf(sString, "%X ", pxRxedMessage->nData[nIndex]);
        } Serial.println("");
        vTaskDelayUntil(&xLastWakeTime, (50 / portTICK_PERIOD_MS));
    }//if xQueue1
void recibir_can() {
  if (xQueue1 != NULL)
    j1939Receive(&xMessage.lPGN, &xMessage.nPriority, &xMessage.nSrcAddr, &xMessage.nDestAddr, xMessage.nData, &xMessage.nDataLen);
    pxMessage = &xMessage;
    xQueueSend(xQueue1, (void *)&pxMessage, (TickType_t)0);
void loop() { }
