can a IIC I2C Level convertor be used with ESP8266 -01 or ESP-201 modules?
can the IIC I2C Logic Level Converter Sensor Module 5V To 3V be used as a level converter for the ESP8266 modules?
The IIC I2C Logic Level Converter is the same as the ones here:
http://www.amazon.com/Logic-Converter-Sensor-Module-Arduino/dp/B00NN6EGZS
and
http://www.dx.com/p/iic-i2c-level-conversion-module-compatible-with-3-5v-system-sensor-blue-197198#.VJroqV4Aw
the ESP8266-01 module is the same as:
https://www.tindie.com/products/azide0x37/esp8266-arduino-compatable-serial-wifi-module-80211-bgn/
The ESP8266 ESP-201 is this one (sorry, can't find an English site)
http://item.taobao.com/item.htm?id=42411337701
The level shifters for I2C don't set the signal high, the pullup resistors are used to make the signal high, and that is slow. I think it will be too slow for SPI.
This page uses a I2C level shifter for SPI, so it might work : https://learn.sparkfun.com/tutorials/using-the-logic-level-converter
