Can a reed switch be normally closed?
I was looking at this:
http://www.sparkfun.com/products/10601
but a magnet seems to connect the switch. Basically I want a device that is "off" (taking no energy) while it is near a magnet, and off when removed near this magnet. I am not sure if a reed switch is the best approach but I know of no other idea. So I wasn't sure also if this reed switch could set to where near magnet its off, and away from it its on. I guess this would mean im looking for a normally closed reed switch?
I have one in my garage:
http://jaycar.com.au/productView.asp?ID=LA5070&keywords=reed&form=KEYWORD
It has 3 terminals: common, normally open and normally closed.
The local DollarTree store has small alarms and lights that are activated when the magnet is moved away from the device (and they are only $1).
You can get single pole changeover reed switches like the one that Nick refers to. Google for "SPDT reed switch".
Here are some:- http://uk.farnell.com/jsp/search/browse.jsp?N=2031+202787+110146364&Ntk=gensearch&Ntt=reed+switch&Ntx=mode+matchallpartial&No=0&getResults=true&appliedparametrics=true&locale=en_UK&divisionLocale=en_UK&catalogId=&skipManufacturer=false&skipParametricAttributeId=&prevNValues=2031+202787&mm=1002918||,&filtersHidden=false&appliedHidden=false&autoApply=true&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D2031%2B202787%26Ntk%3Dgensearch%26Ntt%3Dreed%2Bswitch%26Ntx%3Dmode%2Bmatchallpartial%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_UK%26divisionLocale%3Den_UK%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D2031%2B202787
