can a viriable be size of array when defining/creating array?
can a viriable be size of array when defining/creating array? which is not allowed in original C/C++
how about now?
eg:
int size;
size = 5*2;
char name; /creating array which size is variable/
name[0] = ‘a’;
name[1] = ‘b’;
name[2] = ‘c’;
name[3] = ’ ';
name[4] = ‘d’;
name[5] = ‘e’;
name[6] = ‘f’;
name[7] = ’ ';
name[3] = ‘\0’;
The compiler must know how much memory to allocate to store the array so the array size specifier must be an integer constant. It can be a const variable if that helps
What problem are you trying to solve ?
void someFn (int arraySize)
   char array [arraySize];
in your case, it actually looks like you just want to initialize a string
char name [] = "abc def ";
and you can use strlen() to determine the length of the string excluding the terminating NUL
int len = strlen (name);
in the more general case you can similar statically initialize arrays
int  data [] = { 1, 398, 9, 0, 88 };
and you can use sizeof() to determine the size of the array in bytes and the number of elements
#define N_DATA   (sizeof(data)/sizeof(int))
gcjr:
Use an actual variable to avoid pre-processor macros and take advantage of the compiler's type checking and other diagnostics:
constexpr size_t numElements = (sizeof(data)/sizeof(data[0]));
should that be NumElements ?
ok, the main point is whether a dynamic variable is valid to indicate a size of arrary when array definition.
I learnt C in 1996, and the book and teacher told us again and again never use variable, const variable because the memory is allocated in compile for array, not in running, so need to a number.
eg:
  1. /wrong./
    const int size=3;
    int test;
  2. /wrong./
    int size;
    scanf("%d",&size);
    int test;
  3. /correct./
    #define size 3
    int test;
  4. /correct, same to 3 for compiler will extract Macro./
    int test[3];
and I see following piece is compiled ok,
#define buffer_length 128
uint8_t buffer[buffer_length]; /* this is ok,I see*/
uint8_t block_length = read_block(register, buffer, buffer_length); /* to read i2c, register is int type, buffer is a point, buffer_lenth is int type, return value is the number of value readed int type*/
uint8_t response_length = block_length + 1; /pay attention here 2 lines!!! to use viable to inicate size/
uint8_t response[response_length];/* to creating(define) an array which has one more element */
response[0] = register;/let the first element =register/
for (uint8_t i = 0; i < block_length; i++) /* use loop to fill last elements to new array*/
response[1 + i] = buffer*;*
    for (uint8_t i = 0; i < response_length; i++) /* use loop to output new array*/
    _ serial.print(response*);_
    _
    }_
    so this piece of code is to born a new array and insert an element before the first array than the old array.
    the most important is when these code are valide? is it a new C/C++ standard?
    uint8_t response[response_length];/ to creating(define) an array which has one more element */
    Thanks for everone.
    I did not use C for decades :frowning:
and now is it still a '\0' at the end of a string?
so we must define a one-more-element char array to hold it?
I am outofdate :frowning:
  1. /wrong./
    const int size=3;
    int test;[/quote]Your teacher was wrong.
youxiaojie:
  1. /wrong./ CORRECT
const int size=3;
int test[size];
and now is it still a ‘\0’ at the end of a string?
this
is the quivalent of
char name[size]; /*creating array which size is variable*/
name[0] = 'a';
name[1] = 'b';
name[2] = 'c';
name[3] = ' ';
name[4] = 'd';
name[5] = 'e';
name[6] = 'f';
name[7] = ' ';
name[8] = '0;
     // name[3] = '\0';                       <<<< why set the 3rd byte to NUL?
C handles strings intelligently. it follows the convention of terminating all strings with a NUL character. So the above string length (i.e. strlen()) is 8, but the size of the array (i.e. sizeof()) is 9
