Can a while command exist without being in a loop?
Hi, before I say anything else, this is my first post so I’m sorry if I messed up anywhere.
I’ve been experimenting with arduino for a few days and am getting the hang of it, but one thing that I don’t understand is the for/while commands. It was my understanding that a while(condition) command could be used without being inside another command, but I can only get it to work when it is inside a loop(), like so:
int ledPin = 13;                              // setting pin 13 as ledPin
int count = 0;                                // setting the count for the loop as zero
  pinMode(ledPin, OUTPUT);           // Setting pin 13 as an output to light up an led
void loop(){
  while (count < 10){                    // if variable 'count' is less than ten, continue
    digitalWrite(ledPin, HIGH);        // turn the pin on
    delay(1000);                           // delay one second
    digitalWrite(ledPin, LOW);         // turn the pin off
    count++;                                // add one to the variable 'count'
Is it possible to have a while command without it being inside a loop command?
Thanks!
“loop” isn’t a command, it’s a function, like “setup”.
You can’t have working code outside of a function.
Your “while” loop is the same as writing the “for” loop:
 for ( ;count < 10; count++) {
but it would be better written as:
 for (count = 0; count < 10; count++) {
[edit]FYI, the “loop” function is called inside an infinite “while” loop.[/edit]
@AWOL Sorry for nitpicking but if he intended the loop only to execute the first time through loop() then what you say is better, would lead to a bug. No pun intended :)
In which case, it would have been better in "setup". ;)
Well, not if the purpose of the while-loop was to signal the first entry of loop() :)
Alright, this cleared a lot up for me. Thanks a ton!
Now that my question is answered, do I delete the posting or leave it up?
Leave it - others may find the question relevant.
