Hello again! As usual, I'm using a modified version of this code to experiment with reading SMPTE time code and other biphase-based signals. I wanted to try to read two SMPTE signals simultaneously, but the ATMega328P that I've been using only has one timer capture event. Since the ATMega1284__*__ has two timer capture events (TIMER1_CAPT and TIMER3_CAPT), could I simply copy and paste the ISR, change the name of the timer event in the second ISR to TIMER3_CAPT (and make the other neccessary tweaks with the TCCR1B etc), and read two SMPTE signals simultaneously? I'm not concerned with the serial and all the extra stuff right now, I just want to know if I can decode the bits in the data. If this won't work, is there a way I could do it? Is there a way to do this on the ATMega328P I am using now?
Here is the ISR for convenience:
/* ICR interrupt vector */
ISR(TIMER1_CAPT_vect) //ISR=Interrupt Service Routine, and timer1 capture event
//toggleCaptureEdge
TCCR1B ^= _BV(ICES1); //toggles the edge that triggers the handler so that the duration of both high and low pulses is measured.
bit_time = ICR1; //this is the value the timer generates
//resetTimer1
TCNT1 = 0;
if ((bit_time < one_time_min) || (bit_time > zero_time_max)) // this gets rid of anything that's not what we're looking for
total_bits = 0;
if (ones_bit_count == true) // only count the second ones pluse
ones_bit_count = false;
if (bit_time > zero_time_min)
current_bit = 0;
sync_count = 0;
else //if (bit_time < one_time_max)
ones_bit_count = true;
current_bit = 1;
sync_count++;
if (sync_count == 12) // part of the last two bytes of a timecode word
sync_count = 0;
tc_sync = true;
total_bits = end_sync_position;
if (total_bits <= end_data_position) // timecode runs least to most so we need
{ // to shift things around
tc[0] = tc[0] >> 1;
for(int n=1;n<8;n++) //creates tc[1-8]
if(tc[n] & 1)
tc[n-1] |= 0x80;
tc[n] = tc[n] >> 1;
if(current_bit == 1)
tc[7] |= 0x80;
total_bits++;
if (total_bits == end_smpte_position) // we have the 80th bit
total_bits = 0;
if (tc_sync)
tc_sync = false;
valid_tc_word = true;
if (valid_tc_word)
valid_tc_word = false;
timeCode[10] = (tc[0]&0x0F)+0x30; // frames this converst from binary to decimal giving us the last digit
timeCode[9] = (tc[1]&0x03)+0x30; // 10's of frames this converst from binary to decimal giving us the first digit
timeCode[8] = ':';
timeCode[7] = (tc[2]&0x0F)+0x30; // seconds
timeCode[6] = (tc[3]&0x07)+0x30; // 10's of seconds
timeCode[5] = ':';
timeCode[4] = (tc[4]&0x0F)+0x30; // minutes
timeCode[3] = (tc[5]&0x07)+0x30; // 10's of minutes
timeCode[2] = ':';
timeCode[1] = (tc[6]&0x0F)+0x30; // hours
timeCode[0] = (tc[7]&0x03)+0x30; // 10's of hours
drop_frame_flag = bit_is_set(tc[1], 2); //detects whether theree is the drop frame bit.
write_tc_out = true;
Thanks!
__*__Ignore the fact that the Arduino IDE doesn't directly support the ATMega1284. I'm going to use MightyCore to get around this if it is determined that the ATMega1284 will work the way I want.
