Not sure where to post this, since it won't count as troubleshooting because the problem hasn't happened yet, and I can't find any hardware guidance forum.
Anyway, exactly what it says up top, can your arduino be damaged when it starts running a sketch when you plug it into your computer to download a new one? I'd imagine if your inputs are different it may be a problem...
Then yes. If you put something on a digital pin that draws a lot of current (where a lot is more than 40mA) and your old sketch set it high, you could burn out the pin.
I had the idea as well when I'm changing things quite a bit, that it may not be the best to have the old sketch run with a new setup. I wasn't worried about damaging stuff, but more whether my stuff was in the right position. So, I've started not actually running motors, etc. until I press a button.
The alternative might be to reinstall something harmless like the blink example if you know you are going to change all of the pin assignments.
MichaelMeissner:
The best thing is to install a "blank" sketch with an empty setup() and loop(), before moving the Arduino to a new piece of hardware (unless you know nothing is connected to pin 13 - then the blink sketch is ok).
