Can any bodey help with this errore
E (6317) wifi:sta is connecting, return error
WiFi not connected, running in offline mode...
E (7439) wifi:sta is connecting, return error
Welcome to the forum
When and where do you see this message ?
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
