#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <SoftwareSerial.h>
#include <SPI.h> //the communication interface with the modem
#include "RF24.h" //the library which helps us to control the radio modem (nRF24L)
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *backMotor = AFMS.getMotor(1);
Adafruit_DCMotor *frontMotor = AFMS.getMotor(2);
//Motor A
const int RightMotorForward = AFMS.getMotor(1); // IN1
const int RightMotorBackward = AFMS.getMotor(1); // IN2
//Motor B
const int LeftMotorForward = AFMS.getMotor(2); // IN3
const int LeftMotorBackward = AFMS.getMotor(2); // IN4
int data[0];
RF24 radio(10, 9); //10 and 9 are a digital pin numbers to which signals CE and CSN are connected
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem,that will receive data from the Arduino
//Setup usb serial connection to computer
AFMS.begin(); // create with the default frequency 1.6KHz
AFMS.begin(1000); // OR with a different frequency, say 1KHz
// Set the speed to start, from 0 (off) to 255 (max speed)
backMotor->setSpeed(255);
backMotor->run(FORWARD);
// turn on motor
backMotor->run(RELEASE);
frontMotor->setSpeed(255);
frontMotor->run(FORWARD);
// turn on motor
frontMotor->run(RELEASE);
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
radio.begin(9800); //it activates the modem
radio.openReadingPipe(1, pipe); //determines the address of our modem which receive data
radio.startListening(); //enable receiving data via modem
if (radio.available()) {
radio.read(data, sizeof(data));
//data X
if (data[0] > 550) {
digitalWrite(RightMotorForward, HIGH);
digitalWrite(RightMotorBackward, LOW);
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(LeftMotorBackward, LOW);
Serial.println("FORWARD");
//data X
if (data[0] < 400) {
digitalWrite(RightMotorForward, LOW);
digitalWrite(RightMotorBackward, HIGH);
digitalWrite(LeftMotorForward, LOW);
digitalWrite(LeftMotorBackward, HIGH);
Serial.println("BACKWARD");
backMotor->run(BACKWARD);
//data Y
if (data[1] > 550 ) {
Serial.println("TURN RIGHT");
frontMotor->run(BACKWARD);
//data Y
if (data[1] < 400 ) {
Serial.println("TURN LEFT");
if (data[0] < 550 && data[0] > 400 && data[1] < 550 && data[1] > 400) {
Serial.println("STOP");
//data X
//data X
if (data[110] < 400) {
Serial.println("BACggKWARD");
//data Y
//data Y
if (data[100] < 400 ) {
Serial.println("TURfN LEFT");
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
are commands repeatedly transmitted?
