can any please assist me the program below.
Code tags added by moderator
Ultrasonic Backup Sensor
By David Halloran
Summary:
This program was intended for an automobile backup sensor and takes reeadings from a
PING))) ultrasonic sensor and alerts you to an objects distance in four ways:
 -Numeric readout
 -Color coded zones
 -Bar graph
 -Audible tone
//--------------------- include the library code: ---------------------------
#include <LiquidCrystal.h>
#include <Ping.h>
//--------------------------- Initialize --------------------------------------
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
Ping ping = Ping(13,0,0);
float In = 0;
int green = 2;
int yellow = 3;
int red = 4;
float low = 72;  //Set distance for warnings to start
int med = 0;
int high = 0;
int Inb = 0;
float space =0;
int flash = 0;
char* unit[]={"Feet", "INCHES"};
int u = 1;
//Special Characters for Bar Graph
byte line[8] = {
	B11111,
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B00000,
	B11111
byte block[8] = {
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111,
	B11111
byte car[8] = {
	B11111,
	B01100,
	B11110,
	B00111,
	B00111,
	B11110,
	B01100,
	B11111
byte car1[8] = {
	B11111,
	B00110,
	B11111,
	B11000,
	B11000,
	B11111,
	B00110,
	B11111
//----------------------------- Setup -------------------------------------
  lcd.begin(16, 2);
  pinMode(6, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(yellow, OUTPUT);
  pinMode(red, OUTPUT);
  lcd.createChar(0, line);
  lcd.createChar(1, block);
  lcd.createChar(2, car1);
  lcd.createChar(3, car);
  med = (low/3)*2;          // This breaks your warning distance into three even zones
  high = low/3;             // meaning the program will automatically scale if you
                            // change the start of the first warning zone
//------------------------------ Loop -----------------------------------
  ping.fire();
  In = ping.inches();
  Inb = In;
  if(In > 12){           //If measurement is greater than 12 inches use feet
    space = In/12;
    u = 0;
  }else{                 //else use inches
    space = In;
    u = 1;
  lcd.clear();
  if(In < high){       // Is the object in the Red Zone?
    redLight();
    distance();
    bar();
   else if ((In >= high) && (In < med)){  // Is the object in the Yellow Zone?
     yellowLight();
     distance();
     bar();
   else if ((In >= med) && (In < low)){  // Is the object in the Green Zone?
     greenLight();
     distance();
     bar();
   else if (In > low){           // If no object are in the set range print Drive Safely
    lcd.setCursor(5, 0);
    lcd.print("Drive");
    lcd.setCursor(5, 1);
    lcd.print("Safely");
    noTone(6);               //Tone and lights off
    digitalWrite(red, LOW);
    digitalWrite(yellow, LOW);
    digitalWrite(green, LOW);
  delay(200);
//---------------------- Red Zone ----------------------------
void redLight(){
  tone(6,1440);
  digitalWrite(green, HIGH);
  digitalWrite(yellow, HIGH);
  digitalWrite(red, HIGH);
//--------------------- Yellow Zone ----------------------------
void yellowLight(){
  tone(6,880);
//-------------------- Green Zone ----------------------------
void greenLight(){
  tone(6,440);
//------------------- Print Distance -----------------------
void distance(){
  lcd.setCursor(0, 0);
    lcd.print("Distance: ");
    lcd.setCursor(10, 0);
    lcd.print(space);
    lcd.setCursor(10, 1);
    lcd.print(unit[u]);
//--------------------- Bar Graph ---------------------------
void bar(){
    if (Inb >= ((double)5/(double)6*low)){   //Farthest Away
    lcd.setCursor(0,1);
    lcd.write(2);
    lcd.write(3);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(1);
    else if ((Inb < ((double)5/(double)6*low)) && (Inb >= ((double)4/(double)6*low))){
    lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(2);
    lcd.write(3);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(1);
    else if ((Inb < ((double)4/(double)6*low)) && (Inb >= ((double)3/(double)6*low))){
    lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(0);
    lcd.write(2);
    lcd.write(3);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(1);
    else if ((Inb < ((double)3/(double)6*low)) && (Inb >= ((double)2/(double)6*low))){
    lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(2);
    lcd.write(3);
    lcd.write(0);
    lcd.write(0);
    lcd.write(1);
    else if ((Inb < ((double)2/(double)6*low)) && (Inb >= ((double)1/(double)6*low))){
    lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(2);
    lcd.write(3);
    lcd.write(0);
    lcd.write(1);
  else if (Inb < ((double)1 / (double)6 * low)){  //Closest also makes the graph flash
    if (flash < 1){
      flash = flash++;
    lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(2);
    lcd.write(3);
    lcd.write(1);
    tone(6, 2000);
    else{
      flash = 0;
      lcd.setCursor(0,1);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(0);
    lcd.write(1);
    tone(6, 2000);
Possibly. What assistance do you need? Besides, of course, a lesson in how to post code properly. See the stickies at the top of the forum, before you come back, for that lesson.
What's it do, or not do, or whatever?
Post a schematic of the hardware you have connected also.
it dose not work properly and giving me dis error. Ping ping = Ping(13,0,0);
Did you put the PING and Liquid Crystal libraries in your /libraries folder?
See File:Preferences for the path they should be at.
How do you know it doesn't work if it doesn't even compile?
i try to paste the schematic but could not do it. i have the schematic on the attachment.
Doc1.docx (212 KB)
