can anybody help me in debugging the sketch
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 4);
int sensor1=7;
int sensor2=8;
int sensor3=9;
int speaker1=11;
int speaker1=12;
int Fire_Status;
int sms_count=0;
pinMode(sensor1,INPUT);
pinMode(sensor2,INPUT);
pinMode(sensor3,INPUT);
pinMode(speaker1,OUTPUT);
pinMode(speaker2,OUTPUT);
mySerial.begin(9600);
CheckFire();
CheckShutDown();
void CheckFire()
if(sensor1==LOW)
SetAlert(); // Function to Alerts security
if(sensor1==LOW && sensor2==LOW )
gateOpen();// Function to send SMS
void SetAlert()
digitalWrite(speaker1,HIGH);
void gateOpen()
digitalWrite(speaker2,HIGH);
while(sms_count<3) //Number of SMS Alerts to be sent
SendTextMessage(); // Function to send AT Commands to GSM module
Fire_Status =1;
void CheckShutDown()
if(Fire_Status ==1)
if(sensor1==HIGH)
digitalWrite(speaker,LOW);
sms_count=0;
Fire_Status=0;
void SendTextMessage()
mySerial.println("AT+CMGF=1"); //To send SMS in Text Mode
mySerial.println("AT+CMGS="+919650999749"\r"); // change to the phone number you using
mySerial.println("FIRE IN KPS ”); //the content of the message
delay(200);
mySerial.println((char)26);//the stopping character
mySerial.println("Gas Leaking!");//the content of the message
delay(200);
mySerial.println((char)26);//the message stopping character
sms_count++;
You have to tell us what the problem is. What is the program for? What happens when you run the program and what do you want it to do that is different?
If you did not write the program yourself then please post a link to where you go it.
If you are getting an error when you try to compile the program please post the error message.
...R
PS ... To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
How many times do you think you need to declare/define speaker1?
Use Ctrl+t in the IDE to format your code.
if(sensor1==LOW)
}} // ------------- wrong place for that second }
if(sensor1==HIGH)
digitalWrite(speaker,LOW);  // ----which speaker?
sms_count=0;
Fire_Status=0;
if(sensor1==LOW)
sensor1 has the value 7.
LOW has the value 0.
They are never, ever going to be equal.
Did you forget a digitalRead?
