Can anyone combine 2 programs into 1
Program 1=
#include “EEPROM.h”
#define D1 2 // direction of motor rotation 1
#define M1 3 // PWM left motor
#define D2 4 // direction of motor rotation 2
#define M2 5 // PWM right motor
#define HORN 13 // additional channel 1
//#define autoOFF 2500 // milliseconds after which the robot stops when the connection
#define cmdL ‘L’ // UART-command for left motor
#define cmdR ‘R’ // UART-command for right motor
#define cmdH ‘H’ // UART-command for additional channel (for example Horn)
#define cmdF ‘F’ // UART-command for EEPROM operation
#define cmdr ‘r’ // UART-command for EEPROM operation (read)
#define cmdw ‘w’ // UART-command for EEPROM operation (write)
char incomingByte; // incoming data
char L_Data[4]; // array data for left motor
byte L_index = 0; // index of array L
char R_Data[4]; // array data for right motor
byte R_index = 0; // index of array R
char H_Data[1]; // array data for additional channel
byte H_index = 0; // index of array H
char F_Data[8]; // array data for EEPROM
byte F_index = 0; // index of array F
char command; // command
unsigned long currentTime, lastTimeCommand, autoOFF;
Serial.begin(9600); // initialization UART
pinMode(HORN, OUTPUT); // additional channel
pinMode(D1, OUTPUT); // output for motor rotation
pinMode(D2, OUTPUT); // output for motor rotation
/EEPROM.write(0,255);
EEPROM.write(1,255);
EEPROM.write(2,255);
EEPROM.write(3,255);
timer_init(); // initialization software timer
void timer_init() {
uint8_t sw_autoOFF = EEPROM.read(0); // read EEPROM “is activated or not stopping the car when losing connection”
if(sw_autoOFF == ‘1’){ // if activated
char var_Data[3];
var_Data[0] = EEPROM.read(1);
var_Data[1] = EEPROM.read(2);
var_Data[2] = EEPROM.read(3);
autoOFF = atoi(var_Data)*100; // variable autoOFF ms
else if(sw_autoOFF == ‘0’){
autoOFF = 999999;
else if(sw_autoOFF == 255){
autoOFF = 2500; // if the EEPROM is blank, dafault value is 2.5 sec
currentTime = millis(); // read the time elapsed since application start
if (Serial.available() > 0) { // if received UART data
incomingByte = Serial.read(); // raed byte
if(incomingByte == cmdL) { // if received data for left motor L
command = cmdL; // current command
memset(L_Data,0,sizeof(L_Data)); // clear array
L_index = 0; // resetting array index
else if(incomingByte == cmdR) { // if received data for left motor R
command = cmdR;
memset(R_Data,0,sizeof(R_Data));
R_index = 0;
else if(incomingByte == cmdH) { // if received data for additional channel
command = cmdH;
memset(H_Data,0,sizeof(H_Data));
H_index = 0;
else if(incomingByte == cmdF) { // if received data for EEPROM op
command = cmdF;
memset(F_Data,0,sizeof(F_Data));
F_index = 0;
else if(incomingByte == ‘\r’) command = ‘e’; // end of line
else if(incomingByte == ‘\t’) command = ‘t’; // end of line for EEPROM op
if(command == cmdL && incomingByte != cmdL){
L_Data[L_index] = incomingByte; // store each byte in the array
L_index++; // increment array index
else if(command == cmdR && incomingByte != cmdR){
R_Data[R_index] = incomingByte;
R_index++;
else if(command == cmdH && incomingByte != cmdH){
H_Data[H_index] = incomingByte;
H_index++;
else if(command == cmdF && incomingByte != cmdF){
F_Data[F_index] = incomingByte;
F_index++;
else if(command == ‘e’){ // if we take the line end
Control4WD(atoi(L_Data),atoi(R_Data),atoi(H_Data));
delay(10);
else if(command == ‘t’){ // if we take the EEPROM line end
Flash_Op(F_Data[0],F_Data[1],F_Data[2],F_Data[3],F_Data[4]);
lastTimeCommand = millis(); // read the time elapsed since application start
if(millis() >= (lastTimeCommand + autoOFF)){ // compare the current timer with variable lastTimeCommand + autoOFF
Control4WD(0,0,0); // stop the car
void Control4WD(int mLeft, int mRight, uint8_t Horn){
bool directionL, directionR; // direction of motor rotation L298N
byte valueL, valueR; // PWM M1, M2 (0-255)
if(mLeft > 0){
valueL = mLeft;
directionL = 0;
else if(mLeft < 0){
valueL = 255 - abs(mLeft);
directionL = 1;
else {
directionL = 0;
valueL = 0;
if(mRight > 0){
valueR = mRight;
directionR = 0;
else if(mRight < 0){
valueR = 255 - abs(mRight);
directionR = 1;
else {
directionR = 0;
valueR = 0;
analogWrite(M1, valueL); // set speed for left motor
analogWrite(M2, valueR); // set speed for right motor
digitalWrite(D1, directionL); // set direction of left motor rotation
digitalWrite(D2, directionR); // set direction of right motor rotation
digitalWrite(HORN, Horn); // additional channel
void Flash_Op(char FCMD, uint8_t z1, uint8_t z2, uint8_t z3, uint8_t z4){
if(FCMD == cmdr){ // if EEPROM data read command
Serial.print(“FData:”); // send EEPROM data
Serial.write(EEPROM.read(0)); // read value from the memory with 0 address and print it to UART
Serial.write(EEPROM.read(1));
Serial.write(EEPROM.read(2));
Serial.write(EEPROM.read(3));
Serial.print("\r\n"); // mark the end of the transmission of data EEPROM
else if(FCMD == cmdw){ // if EEPROM data write command
EEPROM.write(0,z1); // z1 record to a memory with 0 address
EEPROM.write(1,z2);
EEPROM.write(2,z3);
EEPROM.write(3,z4);
timer_init(); // reinitialize the timer
Serial.print(“FWOK\r\n”); // send a message that the data is successfully written to EEPROM
Program 2=
The Soccer Robot
Source Code
Made by- Saiyam Agrawal
#include <Servo.h> // import the servo library
Servo myServo;
int incoming = 0;
myServo.attach(3); // initialize servo pin
myServo.write(100); // set the servo to 100 degrees
pinMode(13, OUTPUT); // set all the pins as output
Serial.begin(9600); // connect to BT module
if(Serial.available() > 0) // check if data is available
incoming = Serial.read(); // read the data
digitalWrite(13, HIGH);
switch(incoming)
case ‘X’: // kick
myServo.write(180);
delay(750);
myServo.write(100);
Thanx in advance.I am a new member please forgive me if i am breaking the rules
No, not anyone can do it, else you would have.
If you had read the "how to use the forum" stickies you would know the rules.
Help for merging code http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
thx everyone
