Can anyone find a problem in this code?
The system has 1 button and 3 LEDs. Each time the button is pressed, a new LED state/blinking pattern is initiated, and after the third press the cycle continues. Apparently, my code works for the first button press. After the button was pressed the second time, nothing seemed to happen. I can't for the life of me find where the problem is.
const int light1 = 11;
const int light2 = 12;
const int light3 = 13;
const int buttonpin = 2;   //
int currentstate = 0;     //current state of button
int previousstate = 0;    //previous state of button
int buttoncounter = 0;
const int interval1 = 500;
const int interval2 = 200;
const int interval3 = 300;
unsigned long startpoint = 0;
  pinMode(light1, OUTPUT);
  pinMode(light2, OUTPUT);
  pinMode(light3, OUTPUT);
  pinMode(buttonpin, INPUT);
void loop(){
  currentstate = digitalRead(buttonpin);  //store input value in "currentstate"
  delay(10);                              //debounce
  int val2 = digitalRead(buttonpin);      //debounce
  if (currentstate == val2){              //debounce
  //compare currentstate to previoustate
  if (currentstate != previousstate) {
      buttoncounter++;
      Serial.print("Current state:  ");  //this will print the current state
      Serial.println(buttoncounter);
    previousstate = currentstate;
    if (buttoncounter == 0){        //state 0
      digitalWrite(light1, LOW);
      digitalWrite(light2, LOW);
      digitalWrite(light3, LOW);
    else if (buttoncounter == 1){    //state 1
      digitalWrite(light1, HIGH);
    else if (buttoncounter == 2){
       digitalWrite(light1, LOW);   //state 2
       startpoint = millis();        //set startpoint = the current time in ms
       if (millis() - startpoint >= interval1){   //at 0.5 s
          digitalWrite(light2, HIGH);
          digitalWrite(light3, HIGH);
          if (millis() - startpoint >= interval1){  //at 1.0 s
              if (millis() - startpoint >= interval2){  //at 1.2 s
                if (millis() - startpoint >= interval3){ //at 1.5 s
                  if (millis() - startpoint >= interval3){  //at 1.8 s
                    if (millis() - startpoint >= interval2){  //at 2 s
    else if (buttoncounter >= 3){  //if button is pressed more than two times
      buttoncounter = 0;           //buttoncounter is reset to 0 to repeat the cycle
if (currentstate != val2){ //would be true if there was a change in the switch position
The difference between startpoint and mills() will almost always be 0.
Mark
You keep redefining startpoint, so you case after half a second will occur, but your case after 1.0, 1.5 seconds will never occur, because when you get to 0.5 seconds, you are resetting startpoint again, so the next thing that will happen after that, is you will reach 0.5 seconds again.
