Can anyone help me please to make sketch with 2 sensors
please can anyone help me to combine 2 sensor HC-SR04 in 1 arduino, i have a problem with it. I just can make a sketch with 1 sensor, and when i make it with two, it is not working as what i want. i use motor DC as output, this is my sketc:
// written at: luckylarry.co.uk
//edited by: Hanif and Akmal
// variables to take x number of readings and then average them
// to remove the jitter/noise from the HC-SR04 sonar readings
const int numOfReadings = 10;                   // number of readings to take/ items in the array
int readings[numOfReadings];                    // stores the distance readings in an array
int arrayIndex = 0;                             // arrayIndex of the current item in the array
int total = 0;                                  // stores the cumlative total
unsigned int averageDistance = 0;                        // stores the average value
const int numOfReadings2 = 10;                   // number of readings to take/ items in the array
int readings2[numOfReadings2];                    // stores the distance readings in an array
int arrayIndex2 = 0;                             // arrayIndex of the current item in the array
int total2 = 0;                                  // stores the cumlative total
unsigned int averageDistance2 = 0;
// setup pins and variables for SRF05 sonar device
const int echoPin = 2;                                // SR04 echo pin (digital 2)
const int triggerPin = 3;                            // SR04 trigger pin (digital 3)
unsigned long pulseTime = 0;                    // stores the pulse in Micro Seconds
unsigned long distance = 0;                     // variable for storing the distance (cm)
const int echPin = 7;                                // SR04 echo pin ke 2 (digital 4)
const int triggPin = 6;                            // SR04 trigger pin ke 2 (digital 5)
unsigned long pulseTime2 = 0;                    // stores the pulse in Micro Seconds
unsigned long distance2 = 0;                     // variable for storing the distance (cm)
// setup pins/values for motor
int motor2Pin = 10;
int motor2Value = 0;
int motorPin = 9;                              // motor pin, tersambung ke digital PWM pin 9
int motorValue = 0;
//setup
  pinMode(triggerPin, OUTPUT);                   // set pin trigger sebagai output'
  pinMode(triggPin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(motorPin, OUTPUT);                     // set motor pin sebagai output
  pinMode(echPin, INPUT);
  pinMode(echoPin, INPUT);                      // set echo pin sebagai input
  // create array loop to iterate over every item in the array
  for (int thisReading = 0; thisReading < numOfReadings; thisReading++) {
readings[thisReading] = 0;
// initialize the serial port, lets you view the
 // distances being pinged if connected to computer
// menjalankan perintah
digitalWrite(triggerPin, HIGH);                    // trigger pin dinyalakan
if (averageDistance > 150)                         // jika jarak rata-rata lebih dari 150 cm
analogWrite(motorPin, 0);                         // motor pin tidak bergetar
delayMicroseconds(10);
if (averageDistance <= 150)
analogWrite(motorPin, 250-averageDistance);      //jika jarak rata-ratanya kurang dari sama dengan 150 cm, motor akan bergerak dengan kecepatan sesuai dengan jarak sensor terhadap objek
digitalWrite(triggerPin, LOW);                   // stop sending the pulse
pulseTime = pulseIn(echoPin, HIGH);             // Look for a return pulse, it should be high as the pulse goes low-high-low
distance = pulseTime/58;                        // Distance = pulse time / 58 to convert to cm.
 total= total - readings[arrayIndex];           // subtract the last distance
readings[arrayIndex] = distance;                // add distance reading to array
total= total + readings[arrayIndex];            // add the reading to the total
arrayIndex = arrayIndex + 1;                    // go to the next item in the array
// At the end of the array (10 items) then start again
if (arrayIndex >= numOfReadings)  {
    arrayIndex = 0;
  averageDistance = total / numOfReadings;      // calculate the average distance
  // if the distance is less than 255cm then change the brightness of the LED
  if (averageDistance <= 150) {
    motorValue = 250 - averageDistance;        // semakin dekat jaraknya semakin besar getarannya
  analogWrite(motorPin, motorValue);          // Write current value to LED pins
  //Serial.println(averageDistance, DEC);         // print out the average distance to the debugger
  delay(10);                                   // wait 10 milli seconds before looping again
//sensor kedua
digitalWrite(triggPin, HIGH);                    // trigger pin dinyalakan
if (averageDistance2 > 100)                         // jika jarak rata-rata lebih dari 150 cm
analogWrite(motor2Pin, 0);                         // motor pin tidak bergetar
if (averageDistance2 <= 100)
analogWrite(motor2Pin, 150-averageDistance2);      //jika jarak rata-ratanya kurang dari sama dengan 150 cm, motor akan bergerak dengan kecepatan sesuai dengan jarak sensor terhadap objek
digitalWrite(triggPin, LOW);                   // stop sending the pulse
pulseTime2 = pulseIn(echPin, HIGH);             // Look for a return pulse, it should be high as the pulse goes low-high-low
distance2 = pulseTime2/58;                        // Distance = pulse time / 58 to convert to cm.
 total2= total2 - readings2[arrayIndex2];           // subtract the last distance
readings2[arrayIndex2] = distance2;                // add distance reading to array
total2= total2 + readings2[arrayIndex2];            // add the reading to the total
arrayIndex2 = arrayIndex2 + 1;                    // go to the next item in the array
if (arrayIndex2 >= numOfReadings2)  {
    arrayIndex2 = 0;
  averageDistance2 = total2 / numOfReadings2;      // calculate the average distance
  if (averageDistance2 <= 100) {
    motor2Value = 150 - averageDistance2;        // semakin dekat jaraknya semakin besar getarannya
  analogWrite(motor2Pin, motor2Value);  // Write current value to LED pins
  Serial.print("sensor1: ");
  Serial.print(averageDistance, DEC);
  Serial.print("  sensor2: ");
  Serial.println(averageDistance2, DEC);         // print out the average distance to the debugger
PLEASE HELP ME!!
Such a lot of code, it makes examples and explanations much harder.
Suppose inside of loop() you have code for one sensor but the pin numbers and variables are in arrays such that you can select one sensor and they will be for that or the other sensor?
Suppose further that in setup you have a byte variable that tells to read the first sensor, it will be the array index for all those first sensor values.
Suppose further that in loop(), after whatever sensor is done reading and reporting the code then changes to the other sensor. Back and forth, one sensor is used as loop() goes round and round.
Do you think that may help?
And how it works and how you want it to work are secret?
