Can anyone help me solve these errors?
Hello,
I’m New to coding and arduino field,
I have been working on project - Automatic guitar tuner,
Hardware is Ready but I’m stuck with code part.
I have one which has few errors can anyone help me solve these errors
Code attach below.
Thanks
agt.ino (11.1 KB)
    if (abs(newSlope - maxSlope) //record new data and reset time
Missing closing bracket on if test
Hey,
Thanks for the reply.
Solved two - three errors by your help.
Still getting few errors
Not able to solve Please help… :frowning:
for (byte i=0;i totalTimer+=timer[i]);
exit status 1
expected ‘;’ before ‘totalTimer’
Kindly check the code once again pleaseee
code.ino (11.1 KB)
Are you missing a condition in that “for”?
Like == or < ?
I dont know sir :(
I trying to make project similar to this one http://www.instructables.com/id/Automatic-Guitar-Tuner/
Code provided by author has many errors, need to solve it.
Kindly help sir
It’s an Instructable - what do you expect? :smiley:
Have you got a servo that is capable of turning the guitar tuning knobs ? If so, then how is it powered ?
Yes, I have an Continuous rotation servo, It is powered externally with ground common with arduino.
Hardware part I think it is done but Code is not working can you can guys help to solve the errors?? Please
Have you taken note of the problems pointed out in this thread and corrected them ?
Yes
Now there are new list or errors after correcting them.
NEW ERRORS LIST :
C:\Users\Neel-laptop\Desktop\code\code.ino: In function ‘void __vector_21()’:
code:122: error: expected ‘;’ before ‘totalTimer’
for (byte i=0;i totalTimer+=timer*);*
    C:\Users\Neel-laptop\Desktop\code\code.ino: At global scope:
    code:132: error: expected unqualified-id before ‘else’
    else{//crossing midpoint but not match
    exit status 1
    CODE ATTACHED BELOW.
    code.ino (11.1 KB)
for (byte i=0;i totalTimer+=timer);You're still missing code tags, a condition, and the semicolon at the end of the line should be a little further to the left. I can't see the rest of your code, so you'll have to fix that yourself
Here the small snippet of the code
if (prevData < 127 && newData >=127){//if increasing and crossing midpoint
newSlope = newData - prevData;//calculate slope
if (abs(newSlope-maxSlope)) //record new data and reset time
slope[index] = newSlope;
timer[index] = time;
time = 0;
if (index == 0){//new max slope just reset
PORTB |= B00010000;//set pin 12 high
noMatch = 0;
index++;//increment index
else if (abs(timer[0]-timer[index])) //sum timer values
totalTimer = 0;
period = totalTimer;//set period
//reset new zero index values to compare with
timer[0] = timer[index];
slope[0] = slope[index];
index = 1;//set index to 1
noMatch = 0;
if (index > 9){
reset();
Are you missing braces here?
I dont know :confused: :frowning:
I’m new to coding sir.
I’m Attaching the code .ino file
Can you solve the errors if possible. and attached the code again.
I would be a great help…
Please
code.ino (11.1 KB)
There is a modified version in that instructable in a comment by Timothyi2. That will at least compile.
Whether it does what the original author intended is another question. You will have to ask the questions if it does not work in that instructable. Maybe you're lucky and get a reply.
Code is quite different. And doesnt work for the project. Thats the reason I'm using code given by Author.
But code has few errors.
It would be a great if you guys can help me solve it.
Thanks.
Try fixing this section
totalTimer = 0;
for (byte i=0; i totalTimer+=timer[i])
//  the needed syntax is generally for (byte i=0; some condition such as i <=200; i=i+1)
// so maybe for (byte i=0; i <= something; i = i+1)
  { // do something here? Such as
  totalTimer+=timer[i];
Have you considered to compare your offending statement with the similar statement in the code that I referred to?
