we're planning to display the output of MLX90614 IR sensor to TFT LCD Shield 2.4". I try to search for a code online but I can't find anything. hoping to get something here. anything will do. thanks in advance
Have you tested your sensor with an example sketch from the sensor library?
Have you tested your display with an example sketch for the display library?
If so, post both sketches here. Don't post code without code tags please!
MLX90614 IR sensor
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
while (!Serial);
Serial.println("Adafruit MLX90614 test");
if (!mlx.begin()) {
Serial.println("Error connecting to MLX sensor. Check wiring.");
while (1);
Serial.print("Emissivity = "); Serial.println(mlx.readEmissivity());
Serial.println("================================================");
Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempF());
Serial.print("*F\tObject = "); Serial.print(mlx.readObjectTempF()); Serial.println("*F");
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#define BLACK 0x0000
#define RED 0xF800
#define WHITE 0xFFFF
MCUFRIEND_kbv tft;
uint16_t ID = tft.readID();
tft.begin(ID);
tft.fillScreen(BLACK);
tft.setCursor(0,0);
tft.setTextSize(3);
tft.setTextColor(WHITE);
tft.print("my first project with tft -");
tft.setCursor(0,70);
tft.setTextSize(2);
tft.setTextColor(RED);
tft.print("welcome!");
You didn't say anything about the results of testing those.... two questions were asked, above.
Thanks for using code tags.
There is something missing from that display sketch. I don't see loop() defined?
I already edited the display sample sketch.
I tested those 2 and it works fine with the sensor and display shield
Okay, merge the two sketches. In setup(), the code from both. In loop(), change the print statements to go to the TFT instead of serial. Compile it, and post here.
#include <U8glib.h>
#define RED 0xF800
MCUFRIEND_kbv tft;
while (!Serial);
if (!mlx.begin()) {
while (1);
tft.begin(ID);
tft.setCursor(0,0);
tft.setTextSize(1);
tft.setTextSize(2);
tft.print("*C\tObject = "); tft.print(mlx.readObjectTempC()); tft.println("*C");
tft.println();
delay(5000);
this is the error
*Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
*The sketch name had to be modified.
*Sketch names must start with a letter or number, followed by letters,
*numbers, dashes, dots and underscores. Maximum length is 63 characters.
*wala_lang:31:3: error: 'tft' does not name a type
- tft.begin(ID);
*wala_lang:32:3: error: 'tft' does not name a type
- tft.fillScreen(BLACK);
*wala_lang:33:3: error: 'tft' does not name a type
- tft.setCursor(0,0);
*wala_lang:34:3: error: 'tft' does not name a type
- tft.setTextSize(1);
*wala_lang:35:3: error: 'tft' does not name a type
- tft.setTextColor(WHITE);
*wala_lang:36:3: error: 'tft' does not name a type
- tft.print("my first project with tft -");
*wala_lang:38:1: error: expected declaration before '}' token
*exit status 1
*'tft' does not name a type
*This report would have more information with
*"Show verbose output during compilation"
*option enabled in File -> Preferences.
When you auto format the code, you can see the misplaced {} brace:
#include <U8glib.h>
#define RED 0xF800
MCUFRIEND_kbv tft;
while (!Serial);
if (!mlx.begin()) {
while (1);
tft.begin(ID);
tft.setCursor(0, 0);
tft.setTextSize(1);
tft.setCursor(0, 70);
tft.setTextSize(2);
tft.println();
delay(5000);
That places code outside of any code block, producing those errors.
thanks for the help, sir!!!
