I am a fresher started learning about 4 weeks back, with an Arduino Uno board procured from Amazon, India. I was in the process of trying sketches given in some of the text books I bought from net. I have tried more than 100 simple sketches given in different books.
Everything was fine till today. The last sketch that I tried successfully is pasted below for your reference please.
# include "pitches.h"
int kPinSpeaker = 9;
# define NUM_NOTES 15
const int notes[NUM_NOTES] = {NOTE_C4,NOTE_C4,NOTE_G4,NOTE_G4,NOTE_A4,NOTE_A4,NOTE_G4,NOTE_F4, NOTE_F4,NOTE_E4,NOTE_E4,NOTE_E4, NOTE_D4,NOTE_C4,0};// a 0 represents a rest
const int beats[NUM_NOTES] = {1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4};
-const int beat_length = 300;
pinMode(kPinSpeaker, OUTPUT);
for(int i =0; i<NUM_NOTES; i++){
if(notes[i] == 0) {
delay(beats[i] * beat_length); //rest
else{ourTone(notes[i], beats[1] * beat_length);
//pause between notes
noTone(kPinSpeaker);
delay(beat_length/2);
void ourTone(int freq,int duration)
tone(kPinSpeaker, freq, duration);
delay(duration);
The above coding worked satisfactorily. The only external hardware connected was a piezo buzzer connected between terminals '9 & 'GND'. After this, when I tried to upload another simple code, I am unable to upload the sketch & am getting an error message, which is copied below. I tried resetting the board several times as well as tried uploading some sketches from the EXAMPLE option under FILE menu, but results are same.
Sketch uses 2,580 bytes (7%) of program storage space. Maximum is 32,256 bytes.
Global variables use 204 bytes (9%) of dynamic memory, leaving 1,844 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x71
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x71
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I would be thankful if some of you could help me on this.
Best regards
Anil
