Can anyone help me with correcting this code
int i = 0;
 #include <IRremote.h>
// Sktech from:
//https://gist.github.com/probonopd/5793692#file-sendandreceive-ino
// http://www.pjrc.com/teensy/td_libs_IRremote.html
// If one keypress results in multiple codes being output, then
// change in IRremoteInt.h:
// #define _GAP 50000
// Provided by Robojax.com on August 04, 2018
// Watch Video instruction for this code:https://youtu.be/xA66hXYRx9I
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Compare two tick values, returning 0 if newval is shorter,
// 1 if newval is equal, and 2 if newval is longer
// Use a tolerance of 20%
int compare(unsigned int oldval, unsigned int newval) {
  if (newval < oldval * .8) {
    return 0;
  else if (oldval < newval * .8) {
    return 2;
  else {
    return 1;
// Use FNV hash algorithm: http://isthe.com/chongo/tech/comp/fnv/#FNV-param
#define FNV_PRIME_32 16777619
#define FNV_BASIS_32 2166136261
/* Converts the raw code values into a 32-bit hash code.
 * Hopefully this code is unique for each button.
unsigned long decodeHash(decode_results *results) {
  unsigned long hash = FNV_BASIS_32;
  for (int i = 1; i+2 < results->rawlen; i++) {
    int value =  compare(results->rawbuf[i], results->rawbuf[i+2]);
    // Add value into the hash
    hash = (hash * FNV_PRIME_32) ^ value;
  return hash;
  Serial.println("Robojax IR Capture");
  irrecv.enableIRIn(); // Start the receiver
int c = 1;
void dump(decode_results *results) {
  int count = results->rawlen;
  Serial.println(c);
  c++;
  Serial.println("Hash: ");
  unsigned long hash = decodeHash(results);
  Serial.println(hash, HEX);
  Serial.println("For IR Scope/IrScrutinizer: ");
  for (int i = 1; i < count; i++) {
    if ((i % 2) == 1) {
      Serial.print("+");
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
    else {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
  Serial.println("-127976");
  Serial.println("For Arduino sketch: ");
  Serial.print("unsigned int raw[");
  Serial.print(count, DEC);
  Serial.print("] = {");
    if ((i % 2) == 1) {
    else {
      Serial.print((int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(",");
  Serial.print("};");
  Serial.println("");
  Serial.print("irsend.sendRaw(raw,");
  Serial.print(",38);");
  Serial.println("");
  Serial.println("");
#include <avr/interrupt.h>
#include <stdio.h>
#include <avr/pgmspace.h>
#include <stdint.h>
#include <avr/io.h>
#define IR_PORT PORTB
// #define IR_PIN PINB
// #define IR_DDR DDRB
// #define IR_BV _BV(1)
#define IR_OCR OCR1A
#define IR_TCCRnA TCCR1A
#define IR_TCCRnB TCCR1B
#define IR_TCNTn TCNT1
#define IR_TIFRn TIFR1
#define IR_TIMSKn TIMSK1
#define IR_TOIEn TOIE1
#define IR_ICRn ICR1
#define IR_OCRn OCR1A
#define IR_COMn0 COM1A0
#define IR_COMn1 COM1A1
#define PRONTO_IR_SOURCE 0 // Pronto code byte 0
#define PRONTO_FREQ_CODE 1 // Pronto code byte 1
#define PRONTO_SEQUENCE1_LENGTH 2 // Pronto code byte 2
#define PRONTO_SEQUENCE2_LENGTH 3 // Pronto code byte 3
#define PRONTO_CODE_START 4 // Pronto code byte 4
static const uint16_t *ir_code = NULL;
static uint16_t ir_cycle_count = 0;
static uint32_t ir_total_cycle_count = 0;
static uint8_t ir_seq_index = 0;
static uint8_t ir_led_state = 0;
void ir_on()
  IR_TCCRnA |= (1<<IR_COMn1) + (1<<IR_COMn0);
  ir_led_state = 1;
void ir_off()
  IR_TCCRnA &= ((~(1<<IR_COMn1)) & (~(1<<IR_COMn0)) );
  ir_led_state = 0;
void ir_toggle()
  if (ir_led_state)
    ir_off();
    ir_on();
void ir_start(uint16_t *code)
  ir_code = code;
  // IR_PORT &= ~IR_BV; // Turn output off (atmega328 only)
  digitalWrite(9,LOW); // Turn output off
  // IR_DDR |= IR_BV; // Set it as output (atmega328 only)
  pinMode(9,OUTPUT); // Set it as output
  IR_TCCRnA = 0x00; // Reset the pwm
  IR_TCCRnB = 0x00;
  //printf_P(PSTR("FREQ CODE: %hd"), code[PRONTO_FREQ_CODE]);
  uint16_t top = ( (F_CPU/1000000.0) * code[PRONTO_FREQ_CODE] * 0.241246 ) - 1;
  //printf_P(PSTR("top: %hu"), top);
  IR_ICRn = top;
  IR_OCRn = top >> 1;
  IR_TCCRnA = (1<<WGM11);
  IR_TCCRnB = (1<<WGM13) | (1<<WGM12);
  IR_TCNTn = 0x0000;
  IR_TIFRn = 0x00;
  IR_TIMSKn = 1 << IR_TOIEn;
  ir_seq_index = PRONTO_CODE_START;
  ir_cycle_count = 0;
  ir_on();
  IR_TCCRnB |= (1<<CS10);
#define TOTAL_CYCLES 80000 // Turns off after this number of
// cycles. About 2 seconds
// FIXME: Turn off after having sent
ISR(TIMER1_OVF_vect) {
  uint16_t sequenceIndexEnd;
  uint16_t repeatSequenceIndexStart;
  ir_total_cycle_count++;
  ir_cycle_count++;
  if (ir_cycle_count== ir_code[ir_seq_index]) {
    ir_toggle();
    ir_cycle_count = 0;
    ir_seq_index++;
    sequenceIndexEnd = PRONTO_CODE_START +
      (ir_code[PRONTO_SEQUENCE1_LENGTH]<<1) +
      (ir_code[PRONTO_SEQUENCE2_LENGTH]<<1);
    repeatSequenceIndexStart = PRONTO_CODE_START +
      (ir_code[PRONTO_SEQUENCE1_LENGTH]<<1);
    if (ir_seq_index >= sequenceIndexEnd ) {
      ir_seq_index = repeatSequenceIndexStart;
      if(ir_total_cycle_count>TOTAL_CYCLES) {
        ir_off();
        TCCR1B &= ~(1<<CS10);
void ir_stop()
  IR_TCCRnB = 0x00;
const uint16_t inputLength = 512;
  if (irrecv.decode(&results)) {
    dump(&results);
    irrecv.resume(); // Receive the next value
  if ( Serial.available() > 0 )
    static char input[inputLength];
    static uint16_t i;
    char c = Serial.read();
   if ( c != '' && c != '' && i < inputLength-1)
      i = 0;
      uint16_t array[80];
      uint16_t j = 0;
      if ( !strncmp(input, "SEND", 4) )
        char* p = input+4;
        while ( (p = strchr(p, ' ')) != NULL )
          array[j++] = strtol(p, &p, 16);
        ir_start(array);
        Serial.print("SENT ");
        for ( uint8_t i = 0; i < j; i++ )
          Serial.print ("0x");
          Serial.print (array[i], HEX);
          Serial.print(" ");
For help, explain what the code should do, and what it does instead.
THE CODE HAS TO RECIVE HEX CODES FROM A REMOTE USING IR RECIVER THE CODE RAISES THE FOLLOWING ERROR
sketch_aug01a:234:14: error: empty character constant
C:\Users\POORANI\AppData\Local\Temp\arduino_modified_sketch_302144\sketch_aug01a.ino: In function 'void loop()':
C:\Users\POORANI\AppData\Local\Temp\arduino_modified_sketch_302144\sketch_aug01a.ino:221:29: warning: 'bool IRrecv::decode(decode_results*)' is deprecated: Please use IrReceiver.decode() without a parameter and IrReceiver.decodedIRData. . [-Wdeprecated-declarations]
In file included from C:\Users\POORANI\Documents\Arduino\libraries\IRremote\src/IRremote.h:181:0,
             from C:\Users\POORANI\AppData\Local\Temp\arduino_modified_sketch_302144\sketch_aug01a.ino:2:
C:\Users\POORANI\Documents\Arduino\libraries\IRremote\src/IRReceive.cpp.h:1328:6: note: declared here
bool IRrecv::decode(decode_results *aResults) {
Multiple libraries were found for "IRremote.h"
Used: C:\Users\POORANI\Documents\Arduino\libraries\IRremote
Not used: C:\Users\POORANI\Documents\Arduino\libraries\IRremote-3.3.0
Not used: C:\Users\POORANI\Documents\Arduino\libraries\arduino_635252
exit status 1
No files were added to the sketch.
option enabled in File -> Preferences.
I tried to compile it and it generated an error because the following line has empty character constants. You may have wanted those to be spaces.
if ( c != '' && c != '' && i < inputLength - 1)
Continuing the discussion from Can anyone help me with correcting this code:
I CANT UNDERSTAND THE MEANING OF EMPTY CHARACTER
I TOO RECEIVED THE SAME ERROR.
PRICKYBIKER
Please use lower case letters. UPPER CASE IS LIKE SHOUTING.
An empty character constant is two single quotes with nothing in between them.
Solution: put some sensible character in between the two single quotes. That may require you to figure out what the program is supposed to do.
I have corrected the problem now it raises a new error: missing terminating ' character
We can't see your "correction".
Please remember to use code tags when posting code
