Can anyone please help me to edit the below codes for the sensor (in the link); Arduino; Ammonia sensor; serial communication codes
#include "SoftwareSerial.h"
SoftwareSerial NH3_Serial(12,13); //Sets up a virtual serial port
//Using pin 12 for Rx and pin 13 for Tx
byte readNH3[ ] = {0xFF, 0X01, 0X07, 0X00, 0X00, 0X00, 0X00, 0X00, 0X07}; //Command packet to read NH3 (see app note)
byte response[] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; //create an array to store the response
//multiplier for value. default is 1. set to 3 for K-30 3% and 10 for K-33 ICB
int valMultiplier = 0.1;
Serial.begin(9600); //Opens the main serial port to communicate with the computer
NH3_Serial.begin(9600); //Opens the virtual serial port with a baud of 9600
sendRequest(readNH3);
unsigned long valNH3 = getValue(response);
Serial.print("NH3 ppm = ");
Serial.println(valNH3);
delay(2000);
void sendRequest(byte packet[])
while (!NH3_Serial.available()) //keep sending request until we start to get a response
NH3_Serial.write(readNH3, 8);
delay(50);
int timeout = 0; //set a timeoute counter
while (NH3_Serial.available() < 8 ) //Wait to get a 8 byte response
timeout++;
if (timeout > 10) //if it takes to long there was probably an error
while (NH3_Serial.available()) //flush whatever we have
NH3_Serial.read();
  break;                        //exit and try again
delay(50);
for (int i = 0; i < 8; i++)
response[i] = NH3_Serial.read();
unsigned long getValue(byte packet[])
int high = packet[3]; //high byte for value is 3th byte in packet in the packet
int low = packet[4]; //low byte for value is 4th byte in the packet
unsigned long val = high * 256 + low; //Combine high byte and low byte with this formula to get value
return val * valMultiplier;
Gas Sensor Module-JXCT -- Born for IoT (jxct-iot.com)
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Are these codes you have written yourself or cut and pasted from another coder?
Tom... :smiley: :+1: :coffee: :australia:
