Can anyone please help me with this(Urgent)
I have been doing this project and could not get it to work.It says that checkentered1 was not declared in this scope . http://www.instructables.com/id/Arduino-Combi-button-Lock/
Post your code (use code tags), post the actual error message.
Sorry,im new here,what are code tags
Read this
This is the code
const int button1 = 8; //first button is on pin 8
const int button2 = 9; //second is on pin 9
const int button3 = 10; //third is pin 10
const int button4 = 11; //fourth is pin 11
const int redLed = 4; //red LED is on pin 4
const int greenLed = 12; //green LED is pin 12
int code[] = {1,2,3,4}; //the desired code is entered in this array,
                        //separated by commas
int entered[4]; //create a new empty array for the code entered by
                //the user (has 4 elements)
void setup(){ //run once at sketch startup
  Serial.begin(9600); //begin Serial
  pinMode(button1, INPUT); //button 1 is an input
  pinMode(button2, INPUT); //button 2 is an input
  pinMode(button3, INPUT); //button 3 is an input
  pinMode(button4, INPUT); //button 4 is an input
  pinMode(redLed, OUTPUT); //the red LED is an output
  pinMode(greenLed, OUTPUT); // the green LED is an output
  setupLights(); //run the setupLights routine
  setupLights(); //run it again
  delay(650); //delay (only for effect, :P not needed)
  digitalWrite(redLed, HIGH); //turn the red LED on
  for (int i = 0; i < 4;i++){ //work through numbers 0-3
    Serial.println(code[i]); //print each digit of the code
    Serial.println(entered[i]); //print each element of the entered[]
                                //array (this was for me to check that it
                                //started at 0
void loop(){ //run repeatedly
  if (digitalRead(button1) == HIGH){ //if button1 is pressed
    checkEntered1(1); //call checkEntered and pass it a 1
    delay(250);//wait, needed for correct functioning, otherwise
               //buttons are deemed to be pressed more than once
  else if (digitalRead(button2) == HIGH){ //if button2 is pressed
    checkEntered1(2); //call checkEntered1 and pass it a 2
    delay(250); //wait
  else if (digitalRead(button3) == HIGH){ //if button3 is pressed
    checkEntered1(3); //call checkEntered1 and pass it a 3
    delay(250); //wait
  else if (digitalRead(button4) == HIGH){ //if button4 is pressed
    checkEntered1(4); //call checkEntered1 and pass it a 4
    delay(250); //wait
void checkEntered1(int button /* define the 1,2,3 or 4 as an integer called button */){ //check the first element of the entered[] array
  if (entered[0] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered2(button); //move on to checkEntered2, passing it "button"
  else if(entered[0] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[0] = button; //set the first element as the button that has been pressed
    Serial.print("1: ");Serial.println(entered[0]); //for debugging
void checkEntered2(int button){ //check the second element of the entered[] array
  if (entered[1] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered3(button); //move on to checkEntered3, passing it "button"
  else if(entered[1] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[1] = button; //set the second element as the button that has been pressed
    Serial.print("2: ");Serial.println(entered[1]); //for debugging
void checkEntered3(int button){  //check the third element of the entered[] array
  if (entered[2] != 0){ //if it is not a zero, i.e. it has already been inputted
    checkEntered4(button); //move on to checkEntered4, passing it "button"
  else if (entered[2] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[2] = button; //set the third element as the button that has been pressed
    Serial.print("3: ");Serial.println(entered[2]); //for debugging
void checkEntered4(int button){ //check the fourth element of the entered[] array
  if (entered[3] == 0){ //if it is zero, i.e. if it hasn't been defined with a button yet
    entered[3] = button; //set the final element as the button that has been pressed
    Serial.print("4: ");Serial.println(entered[3]); //for debugging
    delay(100); //allow time for processing
    compareCode(); //call the compareCode function
void compareCode(){ //checks if the code entered is correct by comparing the code[] array with the entered[] array
  for (int i = 0; i<4;i++){ //these three lines are for debugging
    Serial.write(entered[i]);
  if ((entered[0]==code[0]) && (entered[1]==code[1]) && (entered[2]==code[2]) && (entered[3]==code[3])){ //if all the elements of each array are equal
    digitalWrite(redLed, LOW); // turn the red LED off
    digitalWrite(greenLed, HIGH); //turn the green LED on
    delay(100); //wait for a bit
    digitalWrite(greenLed, LOW); //turn the green LED off
    loop(); //return to loop() (not really necessary)
  else { //if you (or the intruder) get the code wrong
    flash(); //call the flash function
    for (int i = 0; i < 4; i++){ //this next loop is for debugging
      entered[i] = 0;
void flash(){ // this is basically the blink example, look at that for an explantion of this, I wont insult your intelligence... oh wait, I already did that earlier when explaining the green LED flashing... sorry 'bout that
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
void setupLights(){ // a funky display run at reset
  digitalWrite(redLed, HIGH); //turn both
  digitalWrite(greenLed, HIGH); //LEDs on
  delay(75); //wait
  digitalWrite(redLed, LOW); //turn them
  digitalWrite(greenLed, LOW); //off again
  delay(75); //wait
And this is the error
Passcode:54: error: 'checkEntered1' was not declared in this scope
Passcode:59: error: 'checkEntered1' was not declared in this scope
Passcode:63: error: 'checkEntered1' was not declared in this scope
Passcode:67: error: 'checkEntered1' was not declared in this scope
exit status 1
Double check this line...
That helped :slight_smile: ,but there are new errors
                                //started at 0
    delay(250); //wait
    delay(250); //wait
    delay(250); //wait
void checkEntered1(int button) /* define the 1,2,3 or 4 as an integer called button */){ //check the first element of the entered[] array
      entered[i] = 0;
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(75); //wait
  delay(75); //wait
This are the new errors
exit status 1
expected initializer before ')' token
*/){lose the )
Try this, shift the void loop() function to bottom
                                //started at 0
      entered[i] = 0;
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(75); //wait
  delay(75); //wait
    delay(250); //wait
    delay(250); //wait
    delay(250); //wait
Just lose the ) - the code below is still wrong
BillHo:
int code = {1,2,3,4}; //the desired code is entered in this array,
  delay(650); //delay (only for effect, :stuck_out_tongue: not needed)
                                //started at 0
void checkEntered1(int button /* define the 1,2,3 or 4 as an integer called button */){ //check the first element of the entered array
    checkEntered2(button); //move on to checkEntered2, passing it “button”
  else if(entered[0] == 0){ //if it is zero, i.e. if it hasn’t been defined with a button yet
void checkEntered2(int button){ //check the second element of the entered array
    checkEntered3(button); //move on to checkEntered3, passing it “button”
  else if(entered[1] == 0){ //if it is zero, i.e. if it hasn’t been defined with a button yet
void checkEntered3(int button){  //check the third element of the entered array
    checkEntered4(button); //move on to checkEntered4, passing it “button”
  else if (entered[2] == 0){ //if it is zero, i.e. if it hasn’t been defined with a button yet
void checkEntered4(int button){ //check the fourth element of the entered array
  if (entered[3] == 0){ //if it is zero, i.e. if it hasn’t been defined with a button yet
void compareCode(){ //checks if the code entered is correct by comparing the code array with the entered array
      entered[i] = 0;
void flash(){ // this is basically the blink example, look at that for an explantion of this, I wont insult your intelligence… oh wait, I already did that earlier when explaining the green LED flashing… sorry 'bout that
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(75); //wait
  delay(75); //wait
    delay(250); //wait
    delay(250); //wait
    delay(250); //wait
AWOL: Just lose the ) - the code below is still wrong
But I had compiled with no error.
Sorry, you're right - but putting a comment in the middle of the function prototype like that is confusing, and didn't look like the OP's last-posted code
"not really necessary" is putting it very mildly. This is a recursive call to loop and will crash your program. Remove it.
Pete
KuriGohan: This is the code
The code compiles fine and free of any errors with Arduino-IDE v1.6.5.-r5 using Win7.
Do you possibly use an old version of Windows/XP for compiling?
I really do despair of most of the Instructables I've seen.
jurs: The code compiles fine and free of any errors with Arduino-IDE v1.6.5.-r5 using Win7.
Just tested with Arduino 1.6.7 on OSX 10.10.5
The comment inside the function definition gives me the same error as OP error. I guess it confuses the pre-compiler. (Re)moving the comment fixes this and then it compiles error free.
Jobi-Wan:
The two latest Arduino IDE versions 1.6.6 and 1.6.7 create many errors with older code.
So if some code is based on an IDE version before 1.6.6 and if it is “URGENT”, better NOT USE 1.6.6 or 1.6.7, but (if possible) use the same version of the IDE which the code was originally written for!
