Hey guys. I'm stuck on a project and trying to figure something out. It usually helps is I can look at different sketches. Does anyone have an HCSR04 sketch that uses two sensors and two LED's? This would help me a lot. Thank you.
Should I reword this, some way?
Ian_McElrath:
You should give it time to go around the world
Peple that might know the answer might be sleeping.
Have you tried something? If so, post it and ecplain what it does do and what you expexted it to do.
Define a second trigger pin, echo pin and led pin and set them up correctly.
Copy yor existing code that does the trigger, reading of the echo and setting of the led and paste it after the current one (assuming you do everything in loop()).
Modify the pasted code to use the new pins.
Compile and run.
