Hello, I dunno how to use microphone, and I'm bad in english, so i can't find any documentation in my lang of quite poor country, can anyone write simple mic arduino program code. There's no need to comment it.
This probably beyond the capabilities of an arduino. There aren't enough resources to store audio. It you wanted it to light an LED if the sound level went above a certain level (VU Meter) then yes, but it would require some extra circuitary on the Microphone. A microphone is AC and Arduinos inputs are strictly DC. Its possible you can add a shield to an Arduino to do audio processing, but the Aduino can't do it alone.
Amplify the microphone signal and feed it into the ADC. If the signal is above a threshold level, light an LED. A single transistor amplifier is all that is required, biased at half the supply voltage.
