Can arduino write variables ?
Hello fello arduinos,
My question is like this. Lets say the value of
int number = 5;
Then i execute a calculation and the value is changed. Lets say
number = 20;
So next time I switch on the arduino I want the "int number" to be 20
Is it possible guys ?
Thanks in advance :slight_smile:
When you switch off the power, all variables are lost and your sketch starts from the beginning.
You need to store the value in the EEPROM or on an external SD card or a battery-buffered RTC chip with RAM
olf2012:
How to store that value in EEPROM ??? Any examples ?
Use the eeprom write anything library.
In setup(), read the value back from eeprom.
CrossRoads:
Thanks and sorry for this noob question. Just now took a look at examples
olf2012:
CrossRoads:
Pls guide me. I used the following example
#include <EEPROM.h>
int re1 = 6;
char inr = 0;
pinMode(re1, OUTPUT);
int re1 = 6;
if (Serial.available() > 0)
inr = Serial.read();
int state = inr - '0';
if (inr == '1')
int ans = EEPROM.read(re1);
Serial.println(state);
digitalWrite(re1, !ans);
EEPROM.write(re1, !ans);
delay(100);
Serial.println("error");
If i switch off and On again I dont get HIGH from pin 6 :o
Can someone help pls ?
