Can 'blocked' code miss an interrupt?
I have a stepper motor running in a bit-banger tight loop to give a "JOG" mode. A button is tied to INT0, and on the first press the loop is entered and the motor starts to run. On the second button press, the flag is set to false and it should stop.
The loop is (basically) like this psuedo code:
while (jogging) {
do steps
The var jogging is a pointer to the var in the main program, which on the first button press is set to true, and the jog function is called, and the motor starts running. When I do the second press, it just sets that var FALSE - but the motor won't stop.
I know the function (a library class I wrote) is reading the 'joggging' flag because if set it false to start - the motor won't run.
It seems that tight loop may be blocking the interrupt as well... Is this true?
I'm using an AttachInterrupt to tie the button press the the jog function - is there some other way I could do this?
=Alan R.
No. The interrupt happens, and then your code resumes running. Why you don't notice it is a mystery, as you posted no code.
Maybe. Without seeing your code, any advice would be worthless.
Buttom bounce issue?
JimEli:
Or floating input wiring for the button. But first the code should be reviewed and if found not wanting then describe how you have the button wired, pull-up/pull-down etc.
If you are attaching using a high or low trigger that can screw the pouch.
Ok - here is the whole situation - hope this extra detail will help.
Interrupted being blocked?
There is a main project with several sketches. There is also a libarary I created to handle the Big Easy Driver. The code works to start the motor (all other functs work - no major coding issues) but will not respond to the toggled boolean and stop.
The switch is wired with a 10k pullup, but not debounced, and tied to Arduino pin 2 which is the pin for INT0. In this instance I don't think debouncing is a BIG issue as I'd see the motor attemtping to stat/stop/start/stop if it was responding to bounces when the switch is pressed. I suspect in some way the interrupt is being blocked when in that while-loop in the libary. Here is a condensed overview of the situtation, with real code fragments:
// In the project:
bool jogging = false;
bool *jogflag = &jogging.
//in setup:
AttachInterrupt(0,BM_Jog,FALLING);
// In project, the BM_Jog function (which is the ISR for INT0) is:
void BM_Jog() {
	jogging == true ? jogging = false : jogging = true;  // Toggle jog mode
	if(!jogging) {
		MotorState = MOTOR_STEPPING;
		jogging = true;
		long rpm = 4;
		BEDMotor.Jog(rpm,jogflag);
// In the Library code here is the BEDMotor.jog func:
void BEDstep::Jog(int rpm, boolean *jogflag) {
	long mdelay = rpm * rpmspeed[cur_rpmspeed];
	while(*jogflag == true) {
		digitalWrite(S_PIN, HIGH);
		delayMicroseconds(mdelay);
		digitalWrite(S_PIN, LOW);
You are not debouncing the button in software, so it had better be debounced in hardware!
Your interrupt routine is calling Jog which has the very while loop that is blocking -
absolute no-no, interrupt routine must simply exit, nothing else can happen till it does.
You communicate between interrupt routine and the rest of the program with variables
declared volatile. Interrupts are asynchronous, and block other interrupts until you
return from the ISR.
You don't need an interrupt to read a button, interrupts are for fast urgent events,
not something on a human timescale.
Also this is amusing:
when you realise there's a logical not operator:
	jogging = !jogging ;
I am a big fan of hardware debouncing. A low pass filter with a schmidtt trigger makes for a very clean signal.
Or, more succinctly jogging = ! jogging;
I notice that the variable jogging is used in both the main program and in the interrupt service routine. Such variables should be declared volatile, as in
volatile bool jogging = false;
As far as I know, accessing jogging via a pointer does not eliminate this requirement.
I am aware of the 'volatile' construct. However when I tried to use it, "C" complained and wouldn't accept it! I'm using Visual Studio 2013 with the Visual Micro add-on. Overall it works pretty good, but maybe it is throwing a 'false positive' in this case. When I get back I'll retry that is the way it should be done.
I changed the flag-toggle to a more explicit way just in case I had the ! = version wrong!
Switch bounce is not to be taken lightly, but in this case it isn't as bad an issue. The motor starts fine, but simply will not stop. Even if the switch was bouncing, with a firm finger press at least one of the bounces should get thru and stop the motor. XD I'm wondering if that tight loop is causing the Arduino to block and miss the interrupts... Next I may put an LED on and use that as a 'breakpoint-light' to show where I am! The Visual Micro debugger won't break there, and I put a manual Serial.Print in the main code where the 'jogging' flag is toggled, and it never prints, so it seems the code may be stuck in that loop.
=A.
As MarkT said:
You don't need an interrupt to read a button, interrupts are for fast urgent events, not something on a human timescale.
I thought I'd made it perfectly clear YOU MUST NOT WAIT WHILE IN AN ISR!!
The presence of a while loop in code called from an ISR should ring alarm bells immediately.
Do your waiting in loop(). Interrupts are only blocked when you explicitly disabled them or are in an ISR already.
