I am programming a 328p which is on a custom board, through an uno with arduino as isp. I can successfully burn a bootloader but trying to upload code spits out this error.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
I am worried as in the bootloader output it states the oscillator as off
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
How is the the target clocked?
Have you adjusted the target's fuses?
I am using the 8mhz internal clock that I set with the bootloader
Sorry if ive misunderstood the question, could you clarify what your asking?
What bootloader did you upload?
Do you plan on programming this device later on using the Tx/Rx inputs? If NO then you don't need a bootloader.
I used the minicore library, I would prefer to program over Rx/tx
I if understand correctly I have changed it from using a 16mhz external clock to the 8mhz internal
Does your custom board include an auto-reset circuit?
Nothing, straight to pin 10 on the uno
When you try uploading to your custom board are you manually resetting? Just before uploading?
I have tried with and without manually resetting the uno just before it uploads
Reburn the bootloader. Post the entire output.
C:\Users\nic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0b11111101:m -Uhfuse:w:0b11010110:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
C:\Users\nic\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:i -Ulock:w:0x0f:m
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0b11111101"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0b11111101:
avrdude: load data efuse data from input file 0b11111101:
avrdude: input file 0b11111101 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0b11010110"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0b11010110:
avrdude: load data hfuse data from input file 0b11010110:
avrdude: input file 0b11010110 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xe2"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xe2:
avrdude: load data lfuse data from input file 0xe2:
avrdude: input file 0xe2 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
Using Port : COM4
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
avrdude: load data flash data from input file C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
avrdude: input file C:\Users\nic\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0f"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
My understanding is the bootloader speed must match the processor speed.
I've downloaded:
One is for 1Mhz clock, the other for a 12Mhz clock.
Does your bootloader match your processor speed (clock)?
I've selected that it is using the 8mhz internal crystal in the minicore boards drop-down. In my understanding this changes the bootloader
in0
March 20, 2022, 2:35pm
19
That is correct. The bootloader which was compiled for 8 MHz processor clock will be automatically used by the Arduino IDE's "Burn Bootloader " operation when you have that menu item selected.
The "8000000L" in the optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex
file name signifies that it was compiled for 8 MHz.
The fuses look correct. (https://www.engbedded.com/fusecalc/ )
The path to the bootloader indicates the correct one is being used...
atmega328p
/8000000L
The burn was successful.
That leaves three things...
The upload baud rate is wrong. This seems unlikely. Choosing the correct target should be enough to get the correct baud rate. It's easy to test: just change upload to verbose then eyeball the top of the output.
You have been unlucky with manual reset. This seems unlikely. You've made several attempts before and after starting an upload.
The TTL-to-USB path is broken. This seems to be the only one left standing.
Try uploading, using ICSP, a simple echo program. The program should write to the serial port everything read from the serial port. In Serial Monitor select the same baud rate used in the echo program then send something. If the sent thing is echoed back then the TTL-to-USB path is fine. If not then that is probably the trouble.
I suggest 9600 or 125,000 baud for the test program. The slew on 9600 is low enough to be irrelevant and 125,000 is a zero error baud for an AVR processor running at 8 MHz. (http://wormfood.net/avrbaudcalc.php ) (http://wormfood.net/avrbaudcalc.php?bitrate=125k&clock=8&databits=8 )
I believe that bootloader includes blinking the pin 13 LED. Do you have an LED connected to pin 13? Does it blink three times about once a second after a reset?
