Can Bus Assistance
Hi everybody,
I’ve been staring at example code for a few days and decided to finally reach out for some help. Not much coding experience aside from basic python.
Some background, I’m using an Arduino Uno along with an MCP2515 to interact with the GMLAN bus on my vehicle. I am able to monitor the bus, and identified which ID’s are important to me along with the relevant message data.
The library I’m using can be seen HERE
Essentially I’m just trying to get this project functional at the most basic level. In english, what I’m hoping to accomplish is
Monitor a Can ID
If [THIS] message data is received
Send [THIS] can message
The can ID I’m monitoring is 0x10758040
It has 3 bytes. At rest it is 82 00 40
When bit ‘2’ becomes a ‘C’ ( changing the message data to 8C 00 40 ), I need the following can message to be sent to
ID 0x10754040
with message data 04 03 00
If anyone could provide me with an example of the if/then statement for how to accomplish this it would really be a life saver.
Hopefully that makes sense. Below are examples of receive & send from the library I’m using.
// CAN Receive Example
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128];                        // Array to store serial string
#define CAN0_INT 2                              // Set INT to pin 2
MCP_CAN CAN0(10);                               // Set CS to pin 10
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
    Serial.println("MCP2515 Initialized Successfully!");
    Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);                     // Set operation mode to normal so the MCP2515 sends acks to received data.
  pinMode(CAN0_INT, INPUT);                            // Configuring pin for /INT input
  Serial.println("MCP2515 Library Receive Example...");
  if(!digitalRead(CAN0_INT))                         // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);      // Read data: len = data length, buf = data byte(s)
    if((rxId & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxId & 0x1FFFFFFF), len);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxId, len);
    Serial.print(msgString);
    if((rxId & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      for(byte i = 0; i<len; i++){
        sprintf(msgString, " 0x%.2X", rxBuf[i]);
  END FILE
// CAN Send Example
#include <SPI.h>
  if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
  else Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);   // Change to normal mode to allow messages to be transmitted
byte data[8] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07};
  // send data:  ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
  byte sndStat = CAN0.sendMsgBuf(0x100, 0, 8, data);
  if(sndStat == CAN_OK){
    Serial.println("Message Sent Successfully!");
    Serial.println("Error Sending Message...");
  delay(100);   // send data per 100ms
  END FILE
something like this maybe (untested, uncompiled):
#include <SPI.h>
  if (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
  byte data[3] = {04, 03, 00};
  if (!digitalRead(CAN0_INT))                        // If CAN0_INT pin is low, read receive buffer
    //can be commented out, only here to for monitoring purposes
    if ((rxId & 0x80000000) == 0x80000000)    // Determine if ID is standard (11 bits) or extended (29 bits)
    Serial.println(msgString);
    if (rxId == 0x10758040) {
      if (rxBuf[0] & 0x0C == 0x0C) { //check byte becomes a 'C'
        byte sndStat = CAN0.sendMsgBuf(0x10754040, 1, 3, data);
        if (sndStat == CAN_OK) {
hope that helps
sherzaad:
hope that helps
that helped a lot, thank you!!
The only thing I had to do was convert my original values from hex to decimal. Just wanted to post the code that worked for me.
#include <SPI.h>
boolean cameraState = false;
  if(CAN0.begin(MCP_ANY, CAN_33K3BPS, MCP_8MHZ) == CAN_OK)
  byte on[3] = {04, 03, 00};
  byte off[3] = {04, 00, 00};
    if((rxId & 0x10758040) == 0x10758040) {
      if (rxBuf[0] == 140) {
        if (cameraState == false) {
            byte sndStat = CAN0.sendMsgBuf(0x10754040, 1, 3, on);
            cameraState = true; }
             { byte sndStat = CAN0.sendMsgBuf(0x10754040, 1, 3, off);
             cameraState = false; }
  END FILE
