Hallo zusammen,
ich Spiel grade an meinem Auto herum.
Ich habe einen Arduino Nano mit einem MPC2515 und 16*2 LCD
Ich schick eine Nachricht auf den CAN und bekomme dann von dem entsprechenden Steuergerät eine Nachricht mit einem Messwertblock den ich auswerten kann.
Momentan mach ich das so:
/* CAN BUS OBD2 - E9X
-------PINOUT-------
* LCD RS pin to digital pin 8
* LCD Enable pin to digital pin 2
* LCD D4 pin to digital pin 7
* LCD D5 pin to digital pin 6
* LCD D6 pin to digital pin 5
* LCD D7 pin to digital pin 4
* LCD R/W pin to ground
* LCD VSS pin to ground
* LCD VCC pin to 5V
* CAN CS to PD 10
* CAN SO to PD 11
* CAN SI to PD 12
* CAN SCK to PD 13
* CAN INT to PD 9
* Button_r to PD 3
* Button_u to PA 0
#include <mcp_can.h>
#include <SPI.h>
#include <LiquidCrystal.h>
#define Button_r 3
//#define Button_u 0;
#define CAN0_INT 9 // Set INT to pin 9
MCP_CAN CAN0(10); // Set CS to pin 10
LiquidCrystal lcd(8, 2, 7, 6, 5, 4); // initialize the library with the numbers of the interface pins
int NB_page = 1; //Variable for page count
//int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char lcdtemp[6];
byte data[8] = {0x12, 0x04, 0x2C, 0x10, 0x0A, 0xF1, 0x00, 0x00}; //Dataframe for Enginetemp request
pinMode(Button_r, INPUT);
lcd.begin(16, 2); // set up the LCD's number of columns and rows:
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK){ // Initialize MCP2515 running at 8MHz with a baudrate of 500kb/s and the masks and filters disabled.
lcd.print("Init OK!");
delay(2000);
//lcd.noDisplay();
}else{
lcd.print("Error Initializing MCP2515...");
delay(2000);
lcd.noDisplay();
// CAN0.init_Mask(0,1,0x1FFFFFFF); // Init first mask...
// CAN0.init_Filt(0,1,0x612);
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
buttonState = digitalRead(Button_r);
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
NB_page++;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(NB_page);
if (NB_page > 2){
NB_page = 1;
delay(50);
lastButtonState = buttonState;
switch (NB_page){
case 1:{
byte sndStat = CAN0.sendMsgBuf(0x6F1, 0, 8, data);
//Serial.print(sndStat);
lcd.setCursor(0,0); // set the cursor to column 0, line 0
lcd.print("Motortemp");
if(sndStat == CAN_OK){
if(!digitalRead(CAN0_INT)){ // If CAN0_INT pin is low, read receive buffer
//Serial.print("Send - ok");
CAN0.readMsgBuf(&rxId, &len, rxBuf);
//Serial.print(rxId);
if(rxId == 0x612){
float temp = (((rxBuf[4]*256)+rxBuf[5])/**0,1)-273,14*/); // calculate Enginetemp in °C
temp = (temp/10)-273,14;
dtostrf(temp,5,1,lcdtemp);
lcd.setCursor(0,2); // set the cursor to column 0, line 0
lcd.print(lcdtemp);
lcd.print(" ");
//lcd.setCursor(1,10);
lcd.print((char)223);
lcd.print("C");
case 2:
//byte sndStat = CAN0.sendMsgBuf(0x6F1, 0, 8, data);
lcd.print("Test - Page 2");
// call function
// do shit
/[code]
Aber ich würde gerne den send und recieve Part in eine Funktion packen aber ich bekomm es einfach nicht hin.
So würde ich es gerne machen aber es klappt nicht:
[code]#include <LiquidCrystal.h>
#include <SPI.h>
#define Button_r 3
#define CAN0_INT 9 // Set INT to pin 2
char msgString[128]; // Array to store serial string
int IDDDE = 0x612;
byte ITMOTtx[8] = {0x12, 0x04, 0x2C, 0x10, 0x0A, 0xF1, 0x00, 0x00};
int ITMOTrxID = 0x6F1;
char lcdtemp[6];
//byte INMOTtx[8];
//byte INMOTrx[8];
int NB_page = 1;
lcd.begin(16, 2);
delay(2000);
//lcd.noDisplay();
}else{
delay(2000);
lcd.noDisplay();
NB_page++;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(NB_page);
if (NB_page > 2){
NB_page = 1;
delay(50);
switch (NB_page){
case 1:{
char ITMOTBuf[8]={0};
//ITMOTBuf[8] = CANrxBuf(ITMOTrxID, IDDDE, ITMOTtx);
ITMOTBuf[8] = *CANrxBuf(ITMOTrxID, IDDDE, ITMOTtx);
float temp = (((ITMOTBuf[4]*256)+ITMOTBuf[5])); // calculate Enginetemp in °C
lcd.print(lcdtemp);
lcd.print(" ");
lcd.setCursor(1,1);
lcd.print("C");
case 2:{
lcd.print("Ladelufttemp");
// unsigned char ITMOTBuf[8] = CANrxBuf(ITMOTrxID, IDDDE, ITMOTtx);
// float temp = (((ITMOTBuf[4]*256)+ITMOTBuf[5])); // calculate Enginetemp in °C
// temp = (temp/10)-273,14;
// dtostrf(temp,5,1,lcdtemp);
// lcd.setCursor(0,2); // set the cursor to column 0, line 0
// lcd.print(lcdtemp);
// lcd.print(" ");
// lcd.setCursor(0,0);
// lcd.print((char)223);
// lcd.print("C");
//---------------------------------------*functions*---------------------------------------------//
char *CANrxBuf( /*int txID,*/ int IDc, byte data[8]){
long unsigned int rxID;
//char msgString[128]; // Array to store serial string
// send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
CAN0.readMsgBuf(&rxID, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if(rxID == IDc){
for(byte i = 0; i<len; i++){
sprintf(msgString, " 0x%.2X", rxBuf[i]);
Serial.print(msgString);
return msgString;
//------OR-----------
//if(rxID == IDc){
//return rxBuf;
Kann mir jemand helfen den send und recieve Part in eine Funktion zu packen?
Danke für eure Hilfe!
