Hello all,
I am trying to communicate MCP2515 with Kvaser light V2 CAN bus analyzer. I have used MCP2515 shield 1.5 on arduino uno. I have gone through sample codes for can send as well as receive. I want send as well as receive so I have merged both programs.
Sending is working well but there is problem in receiving data.
I have attached my code so please find the attachment and help me.
#include <Wire.h>
#include <CAN.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
//Adafruit_ADS1015 ads; /* Use this for the 12-bit version */
int timer1_counter;
uint16_t adc0;
uint8_t adch,adcl;
#define ledPin 5
void setup(void)
while (!Serial);
pinMode(ledPin, OUTPUT);
// initialize timer1
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
// Set timer1_counter to the correct value for our interrupt interval
timer1_counter = 64930; // preload timer 65536-16MHz/256/100Hz 10ms 64911
//timer1_counter = 64911; // preload timer 65536-16MHz/256/100Hz
//timer1_counter = 64286; // preload timer 65536-16MHz/256/50Hz
//timer1_counter = 34286; // preload timer 65536-16MHz/256/2Hz
// timer1_counter = 62411; // preload timer 65536-16MHz/256/20Hz 100msec
TCNT1 = timer1_counter; // preload timer
TCCR1B |= (1 << CS12); // 256 prescaler
//TCCR1B |= (1 << CS11) | (1 << CS10); // 64 prescaler
TIMSK1 |= (1 << TOIE1); // enable timer overflow interrupt
interrupts(); // enable all interrupts
Serial.println("CAN Sender");
Serial.println("Hello!");
Serial.println("Getting single-ended readings from AIN0..3");
Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
ads.begin();
// start the CAN bus at 500 kbps
if (!CAN.begin(500E3)) {
Serial.println("Starting CAN failed!");
while (1);
ISR(TIMER1_OVF_vect) // interrupt service routine
digitalWrite(ledPin, digitalRead(ledPin) ^ 1);
// send extended packet: id is 29 bits, packet can contain up to 8 bytes of data
//Serial.print("Sending extended packet ... ");
CAN.beginExtendedPacket(0x0C00DAEF); //(PGN-0 Priority-3 src Addr- EF Dest Addr-DA)
CAN.write(0xFF);
CAN.write(adch);
CAN.write(adcl);
CAN.write(0xFF);
CAN.write(0xFF);
CAN.write(0xFF);
CAN.write(0xFF);
CAN.write(0xFF);
CAN.endPacket();
Serial.println(" ");
void loop(void)
adc0 = ads.readADC_SingleEnded(0);// 10v = 64255 = 8031.875 max value speed. adjust 10v = 32127 counts.
adc0 = adc0 * 2;
adch = adc0 >> 8;
adcl = adc0 & 0x00FF;
Serial.print("AIN0: "); Serial.println(adc0);
Serial.println(adch);
Serial.println(adcl);
// try to parse packet
int packetSize = CAN.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received ");
if (CAN.packetExtended()) {
Serial.print("extended ");
if (CAN.packetRtr()) {
// Remote transmission request, packet contains no data
Serial.print("RTR ");
Serial.print("packet with id 0x");
Serial.print(CAN.packetId(), HEX);
Serial.print(" and requested length ");
Serial.println(CAN.packetDlc());
Serial.print(" and length ");
Serial.println(packetSize);
// only print packet data for non-RTR packets
while (CAN.available()) {
Serial.print((char)CAN.read());
