Can Bus filter not working
Hello,
It's probably something simple, but I can't get a can bus filter working for message ID's 280 & 288, I can get the data from the car;
Standard ID: 0x280 DLC: 8 Data: 0x09 0x6D 0x00 0x00 0x4B 0x00 0x2D 0x4B
Standard ID: 0x4A8 DLC: 8 Data: 0xFF 0x7F 0x01 0x00 0x00 0x00 0x80 0x01
Standard ID: 0x0C2 DLC: 8 Data: 0x00 0x80 0x00 0x80 0x04 0x92 0x00 0x6D
Standard ID: 0x288 DLC: 8 Data: 0x0A 0x4E 0x10 0x00 0x00 0x82 0x92 0x5D
Standard ID: 0x5A0 DLC: 8 Data: 0x64 0x01 0x00 0x61 0xEC 0x01 0x00 0x2B
Standard ID: 0x1A0 DLC: 8 Data: 0x00 0x43 0x00 0x00 0xFE 0xFE 0x00 0x99
But when I try to apply a filter;
CAN0.init_Mask( 0, 1, 280 | 288 );          // Init first mask...
CAN0.init_Filt( 0, 1, 280 );                // Init 1st filter...
CAN0.init_Filt( 1, 1, 288 );                // Init 2nd filter...
I still get all the ID's data?
I tried the below as I read that all the masked & filters need to be populated;
CAN0.init_Mask( 1, 1, 0b100011000 );          // Init first mask...
CAN0.init_Filt( 2, 1, 0b100011000 );                // Init 3rd filter...
CAN0.init_Filt( 3, 1, 0b100011000 );                // Init 4th filter...
CAN0.init_Filt( 4, 1, 0b100011000 );                // Init 5th filter...
CAN0.init_Filt( 5, 1, 0b100011000 );                // Init 6th filter...
Still didn't work.
I'm getting the;
Starting to Set Mask!
Setting Mask Successful!
Starting to Set Filter!
Setting Filter Successful!
messages OK.
Any advice would be most appreciated.
// CAN Receive Example
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128];                        // Array to store serial string
#define CAN0_INT 2                              // Set INT to pin 2
MCP_CAN CAN0(10);                               // Set CS to pin 10
void setup(){
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
  else Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);                     // Set operation mode to normal so the MCP2515 sends acks to received data.
  pinMode(2, INPUT);                            // Setting pin 2 for /INT input
  pinMode(CAN0_INT, INPUT);                            // Configuring pin for /INT input
  Serial.println("MCP2515 Library Receive Example...");
  if(!digitalRead(2))                         // If pin 2 is low, read receive buffer
  if(!digitalRead(CAN0_INT))                         // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);      // Read data: len = data length, buf = data byte(s)
    if((rxId & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxId & 0x1FFFFFFF), len);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxId, len);
    Serial.print(msgString);
    if((rxId & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      for(byte i = 0; i<len; i++){
        sprintf(msgString, " 0x%.2X", rxBuf[i]);
If anyone else has the same problem, this worked;
#include <SPI.h>
  if(CAN0.begin(MCP_STDEXT, CAN_500KBPS, MCP_8MHZ) == CAN_OK) Serial.print("MCP2515 Init Okay!!\r\n");
  else Serial.print("MCP2515 Init Failed!!\r\n");
CAN0.init_Mask( 0, 0, 280 | 288 );          // Init first mask...
CAN0.init_Filt( 0, 0, 280 );                // Init 1st filter...
CAN0.init_Filt( 1, 0, 288 );                // Init 2nd filter...
CAN0.init_Mask( 1, 0, 280 | 288 );          // Init first mask...
CAN0.init_Filt( 2, 0, 280 );                // Init 1st filter...
CAN0.init_Filt( 3, 0, 288 );                // Init 2nd filter...
CAN0.init_Filt( 4, 0, 280 );                // Init 1st filter...
CAN0.init_Filt( 5, 0, 288 );                // Init 2nd filter...
  Serial.println("MCP2515 Library Mask & Filter Example...");
  CAN0.setMode(MCP_NORMAL);                // Change to normal mode to allow messages to be transmitted
      Serial.print("ID: ");
      Serial.print(rxId, HEX);
      Serial.print(" Data: ");
      for(int i = 0; i<len; i++)           // Print each byte of the data
        if(rxBuf[i] < 0x10)                // If data byte is less than 0x10, add a leading zero
          Serial.print("0");
        Serial.print(rxBuf[i], HEX);
        Serial.print(" ");
