Can bus help
Hi Gents
please help to solve
i'm trying to send some frames from sd card. Serial printing of data is correct before send , but on can bus port readed data field is empty (clear) id and rest is fine
any ideas ??
its some memory collision while reading sd at --buffer = printFile.readStringUntil('\n');
//*********************** SD **********************
Can0.begin(CAN_BPS_125K);
Can0.watchFor();
void sendData()
SysCall::yield();
if (!sd.begin(chipSelect, SPI_SIXTEENTH_SPEED)) {
sd.initErrorHalt();
openfile:
mydisp.clearScreen();
if (! printFile.open("Run.txt", O_READ))
{ sd.errorHalt("opening test.txt for read failed");
mydisp.println("card failure ");
while (printFile.available()) {
CAN_FRAME outgoing;
outgoing.id = strtol(buffer.substring(0,8).c_str(), NULL, 16);
outgoing.extended = true;
outgoing.priority = 4; //0-15 lower is higher priority
outgoing.data.byte[7] = strtol(buffer.substring(9,11).c_str(), NULL, 16);
outgoing.data.byte[6] = strtol(buffer.substring(12,14).c_str(), NULL, 16);
outgoing.data.byte[5] = strtol(buffer.substring(15,17).c_str(), NULL, 16);
outgoing.data.byte[4] = strtol(buffer.substring(18,20).c_str(), NULL, 16);
outgoing.data.byte[3] = strtol(buffer.substring(21,23).c_str(), NULL, 16);
outgoing.data.byte[2] = strtol(buffer.substring(24,26).c_str(), NULL, 16);
outgoing.data.byte[1] = strtol(buffer.substring(27,29).c_str(), NULL, 16);
outgoing.data.byte[0] = strtol(buffer.substring(30,32).c_str(), NULL, 16);
Can0.sendFrame(outgoing);
Serial.print(outgoing.id,HEX);Serial.print(" "); Serial.print(outgoing.data.high,HEX);Serial.println(outgoing.data.low,HEX);
delay (1000);
printFile.close();
//goto openfile;
sendData();
delay (1000);
Make sure to set rtr to 0 when you are sending frames. If RTR were to get set you'd be sending a remote data request and wouldn't have data bytes. Perhaps I should have added a constructor that sets the various parameters to sane values. As it sits CAN_FRAME is a struct with no constructor so no attempt is made to set anything to a realistic value. Thus, always set id, length, priority, data bytes, rtr, and extended or they might default to something dumb.
