My set up:
CAN A: has the diagnostic tool
CAN B: has the node ECU
I have installed a Arduino in between the CAN networks. Creating a physical CAN gateway. I started with simply transferring the signals from CAN A to CAN B and in the reverse. Essentially the traffic moved as if nothing was there. However, I have now tried receiving a multi frame signal and then altering some of the byte data and sending it back on bus. My observations are that 'VIN_reuest == true' seems to not allow it to go into the loop. And also without the 'VIN request' there still the if statements with count don't alter the CAN message. The original CAN message is just returned.
Has anyone done this before, am I going in the right direction?
I have done this in the past with single CAN messages.
#include <mcp2515.h> //Library for CAN interfaces
#include <SPI.h> //Library for using SPI Communication
//Define the CS pin for each MCP2515 board
const int CS_PIN_1 = 9;
const int CS_PIN_2 = 10;
//create instances of the MCP2515 class for each board
MCP2515 mcp2515_1(CS_PIN_1);
MCP2515 mcp2515_2(CS_PIN_2);
struct can_frame canMsg;
bool VIN_request = false;
int count = 0;
bool VIN_reuest = false;
SPI.begin(); //Begins SPI communication
Serial.begin(9600); //Begins Serial Communication at 9600 baudrate
mcp2515_1.reset();
mcp2515_2.reset();
mcp2515_1.setBitrate(CAN_500KBPS,MCP_8MHZ); //Sets CAN at speed 500KBPS and Clock 8MHz
mcp2515_2.setBitrate(CAN_500KBPS,MCP_8MHZ);
mcp2515_1.setNormalMode(); //Sets CAN at normal mode
mcp2515_2.setNormalMode(); //Sets CAN at normal mode
// Reading diagnostic side and sending to ECU side
if (mcp2515_2.readMessage(&canMsg) == MCP2515::ERROR_OK) {
if (canMsg.can_id == 0x740) {
// Set VIN flag to true when request 1A 90 is found
if (canMsg.data[3] == 0x1A && canMsg.data[4] == 0x90) {
VIN_request = true;
count = 0; // Reset count for new request
//lastSendTime = millis(); // Reset timer
mcp2515_1.sendMessage(&canMsg);
// Reading ECU side and sending to diagnostic side with VIN modifications
if (mcp2515_1.readMessage(&canMsg) == MCP2515::ERROR_OK) {
//if (VIN_reuest == true && canMsg.can_id == 0x300) {
if (canMsg.can_id == 0x300) {
//if (millis() - lastSendTime >= 20) { // Ensure 20 ms interval
Serial.println("Inside");
Serial.println(count);
// canMsg.data[3] = 0x00;
// canMsg.data[4] = 0x00;
// canMsg.data[5] = 0x00;
// canMsg.data[6] = 0x00;
// canMsg.data[7] = 0x00;
if (count == 0) {
// Adjust first message data
count++;
else if (count == 1) {
// Adjust second message data
canMsg.data[1] = 0x00;
canMsg.data[2] = 0x00;
count++;
else if (count == 2) {
// Adjust third message data
canMsg.data[0] = 0x00;
// Reset flags for the next request
count = 0;
// Send the modified message and update time
mcp2515_2.sendMessage(&canMsg);
//lastSendTime = millis(); // Update last sent time
else {
// Pass through other messages
