CAN BUS Menu System - Timing of replaying messages/Code Issue
Hi all,
For my project I have been using a CAN BUS Shield to sniff messages on the CAN BUS of a car, and then replay the messages. I have several messages that I want to send back to the car, and have implemented a menu system.
However when I choose an option to send back to the car, It will only work for a split second. I want the message to continue until I choose a different option. The messages worked individually before I put them all in the menu system and the main loop. Is it because they are all in the main loop together that it wont work as I want?
Here is my code:
.edit
Any thoughts or input appreciated!
So take everything out of the while loop.
So I just need to delete the "while(Serial.available()" and the associated curly brackets and all should be good ?
I have a feeling this will lead to loads of errors ?
char UserInput; //global
if(Serial.available())
  UserInput = Serial.read();
//rest of code here
Much appreciated. Thank you
