I’ve connected the arduino to my car’s can-bus system using autowp/arduino-mcp2515 library.
My goal is to read RPM frames and update the rpm value of the program.
I’ve found an excell formula online for calculating the rpm value:
The problem is my coding knowledge is not sufficient to do it. In the code above I am getting 0.00.
If I calculate the value manually by taking what serial print is showing me, for example third data byte: 12, second is: 3F and add them as strings 123F (4671 in decimal) and divide the number by 6.4 I am getting the correct value 729.84.
You need to do the same calculations with the Arduino. I do not believe you need to use float, I know of no vehicle that sends RPM as a floating point number.
gilshultz:
Well yes, this is exactly where I am failing. Should I somehow convert byte to HEX string and then add them? (any tips on that? I’ve tried googling but all cases were too difficult to understand)
Of course I don’t receive it as float, I thought the result after the division would be though.
I would have a look at the examples that come with a number of these shields - there are examples translating the PID code returns , how they are made up etc .
In case anyone will have same issue this is how I’ve solved it: String(canMsg.data[3], HEX) converts in to the hex string, all that was remaining was to convert hex string back strtoul(hexString.c_str(), NULL, 16)
