CAN BUS Problem bei stmp!
Hallo.
Bitte um tips! Bei einfache Programm ist ein fehler aber ich kann ihm nicht finden!
Can Bus soll nachricht senden. Er sendet kein "stmp"
#include <Wire.h>
#include <SPI.h>
#define CAN_2515
#if defined(SEEED_WIO_TERMINAL) && defined(CAN_2518FD)
const int SPI_CS_PIN = BCM8;
const int CAN_INT_PIN = BCM25;
#else
const int SPI_CS_PIN = 10;
const int CAN_INT_PIN = 2;
#endif
#ifdef CAN_2518FD
#include "mcp2518_can.h"
mcp2518fd CAN(SPI_CS_PIN); // Set CS pin
#endif
#ifdef CAN_2515
#include "mcp2515_can.h"
mcp2515_can CAN(SPI_CS_PIN); // Set CS pin
#endif
SERIAL_PORT_MONITOR.begin(9600);
while(!Serial){};
while (CAN_OK != CAN.begin(CAN_500KBPS)) {             // init can bus : baudrate = 500k
    SERIAL_PORT_MONITOR.println("CAN init fail");
    delay(100);
unsigned char stmp[8] = {0, 1, 2, 3, 4, 5, 6, 7};
  • stmp[0] = 0x01; // 1 = Laden ON*
  • stmp[1] = 0xE8; // 3E8 = 1000 = 100% liefern*
** stmp[2] = 0x03;**
** stmp[3] = 0x0E; //F6E = 3950 = 395V maximal**
** stmp[4] = 0xF6;**
** stmp[5] = 0x50; //50 = 80 = 8A maximal**
** stmp[6] = 0x00;**
** stmp[7] = 0x00;**
CAN.sendMsgBuf(0x2ff,0,0,0,stmp); // stmp sendet nicht!!!!
delay(950);
Where did you get the library from?
I found this...
Maybe you need?
CAN.sendMsgBuf(0x2ff,0,8,stmp);
Hy. From ther: CAN-BUS Shield V2.0 - Seeed Wiki
Da sehe ich:
grafik
Arduino: 1.8.18 (Windows 10), Board: "Arduino Uno"
C:\Users\adamn\OneDrive\Dokumente\Arduino\CANladen\CANladen.ino: In function 'void loop()':
CANladen:98:34: error: no matching function for call to 'mcp2515_can::sendMsgBuf(int, int, int, unsigned char [8])'
In file included from C:\Users\adamn\OneDrive\Dokumente\Arduino\CANladen\CANladen.ino:44:0:
C:\Users\adamn\OneDrive\Dokumente\Arduino\libraries\Seeed_Arduino_CAN-master\src/mcp2515_can.h:93:18: note: candidate: virtual byte mcp2515_can::sendMsgBuf(byte, long unsigned int, byte, byte, byte, const volatile byte*)
 virtual byte sendMsgBuf(byte status, unsigned long id, byte ext, byte rtrBit, byte len, volatile const byte *buf);                                  // send message buf by using parsed buffer status
C:\Users\adamn\OneDrive\Dokumente\Arduino\libraries\Seeed_Arduino_CAN-master\src/mcp2515_can.h:93:18: note: candidate expects 6 arguments, 4 provided
C:\Users\adamn\OneDrive\Dokumente\Arduino\libraries\Seeed_Arduino_CAN-master\src/mcp2515_can.h:94:18: note: candidate: virtual byte mcp2515_can::sendMsgBuf(long unsigned int, byte, byte, byte, const byte*, bool)
 virtual byte sendMsgBuf(unsigned long id, byte ext, byte rtrBit, byte len, const byte *buf, bool wait_sent = true);                                 // send buf
C:\Users\adamn\OneDrive\Dokumente\Arduino\libraries\Seeed_Arduino_CAN-master\src/mcp2515_can.h:94:18: note: candidate expects 6 arguments, 4 provided
exit status 1
Ich glaube das library hat ein problem
Wenn Du Dein Programm in #1 ordentlich formatierst, könnte ich es mal in meine IDE kopieren und schauen, was bei mir passiert.
Mir fällt gerade auf, wenn Du die Anzahl der zu sendenden Bytes auf Null setzt, wird wohl nichts gesendet. Also mal so probieren:
CAN.sendMsgBuf(0x2ff, 0, 0, 8, stmp);
#include <Wire.h>
#include <SPI.h>
#define CAN_2515
#else
#endif
#ifdef CAN_2518FD
#endif
#ifdef CAN_2515
#endif
const int LED        = 8;
boolean ledON        = 1;
    pinMode(LED, OUTPUT);
    while(!Serial){};
SERIAL_PORT_MONITOR.println("CAN init ok!");
unsigned char stmp[8] = {0,1, 2, 3, 4};
    stmp[1] = 0xE8;
    stmp[2] = 0x03;
    stmp[3] = 0x74;
    stmp[4] = 0x04;
    stmp[5] = 0x64;
    stmp[6] = 0x00;
    stmp[7] = 0x00;
    CAN.sendMsgBuf(0x2ff,0,0,8,stmp); //(long unsigned int, byte, byte, byte, const byte*, bool)
    unsigned char len = 0;
    unsigned char buf[8];
    if (CAN_MSGAVAIL == CAN.checkReceive()) {         // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned long canId = CAN.getCanId();
        SERIAL_PORT_MONITOR.println("-----------------------------");
        SERIAL_PORT_MONITOR.println("get data from ID: 0x");
        SERIAL_PORT_MONITOR.println(canId, HEX);
        for (int i = 0; i < len; i++) { // print the data
            SERIAL_PORT_MONITOR.print(buf[i]);
            SERIAL_PORT_MONITOR.print("\t");
            if (ledON && i == 0) {
                digitalWrite(LED, buf[i]);
                ledON = 0;
                delay(950);
            } else if ((!(ledON)) && i == 4) {
                ledON = 1;
        SERIAL_PORT_MONITOR.println();
    delay(950);
ich weiß nicht was los aber jetzt ghet's nur ich bekomme 3 can nachrichten zusammen
Mit delay den Datenempfang zu blockieren, halte ich für keine gute Idee.
