CAN BUS Problem Receiving with Serial
horace:
did you connect your cluster to the ElecFreaks CAN BUS Shield D type connector or to the screw terminals?
if you connected to the 9 pin Dtype connector looking at the schematic the ElecFreaks CAN BUS Shield the pin out is CAN high is pin 3 and CAN low is pin 5
on all my other canbus kit the pin out is CAN low is pin 2 and CAN high is pin 7 with CAN_GND pin 3
I would recommend you get a USB-CAN dongle for a PC so you can check that the ElecFreaks CAN BUS Shield is working correctly
I have CAN H and CAN L connected to the screw terminals on the board. Is this not the correct location for them?
I will look into the USB-CAN dongle, although I may try the Seeed CAN BUS shield before shelling out $120 for the dongle. Appreciate the links
