I am trying to read datas that are coming from canoe but it seems there is no available CAN data. There is Tx message on Canoe but it is not readable via arduino. What are the connection steps between Canoe and Arduino?
Please do not post screenshots of code. See How to get the best out of this forum how to post code using code tags. Please post complete code, not snippets.
Did you write the code yourself or is it one the the examples.
You can spend weeks spinning your wheels or you may get lucky and get your problem solved. We cannot see what you have in detail so we ask for an annotated schematic as you have it wired showing all connections including power, ground, supplies etc. I will normally spend a moment on a question if it is missing information I need I ask, if somebody has asked for it, great but if it is missing that I wonder if the OP is serious and probably will just go to another question. We also know there are many modules etc that look alike and may be called the same thing but they are different, that is why we ask for links to "Technical Information". We also know a lot stuff is purchased from the azon marketplace by sellers that do not know what they are selling and they do not bother to add all the technical information.
