CAN_BUS Received get crashed with ESP32
Hi, I'm working with two ESP32 with a MCP2515 device to create a CAN-BUS network, my problem is the ESP32 that is getting the data, when it receives the message it get crashed. I know how to solve the problem, here is the code of the code to send messages:
#include <SPI.h>
#include "mcp_can.h"
#ifdef ESP32
  #define SPI_CS 5
  #define CAN_INT 4
#else
  #define SPI_CS 10
  #define CAN_INT 2
#endif
MCP_CAN CAN0(SPI_CS);
long id = 0x53;
byte data[1];
  while(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) != CAN_OK)Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);
  Serial.println("MCP2515 Initialized Successfully!");
  if(Serial.available()){
    char c = Serial.read();
    Serial.print("Valor de ");
    Serial.print(c);
    Serial.print(" enviar: ");
    Serial.println(c,HEX);
    data[0] = c;
    byte sndState = CAN0.sendMsgBuf(id,0,1,data);
    if(sndState == CAN_OK){
      Serial.println("Message Sent Successfully!");
    else {
    Serial.println("Error Sending Message...");
    delay(100);
And this is the code to receive the message:
#include <SPI.h>
#ifdef ESP32
  #define SPI_CS 5
  #define CAN_INT 4
#else
  #define SPI_CS 10
  #define CAN_INT 2
#endif
  pinMode(CAN_INT,INPUT);
unsigned long rxId;
unsigned char len;
unsigned char rxBuff[8];
  if(!digitalRead(CAN_INT))
    CAN0.readMsgBuf(&rxId, &len, rxBuff);
the error when I get a Message is the next:
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
if anybody knows how to solve this problem or knows another library to work with the ESP32 and MCP2515, please let me to know, I will be greatefull
Post a simple schematic showing the network, all termination etc, Hopefully it is at least a meter or more in length.
Why not just solve the problem?
Here are some links about the Guru meditation error:
don't know if it will help but I added PULLUP to
 pinMode(CAN0_INT, INPUT_PULLUP);  // Configuring pin for /INT input *** added PULLUP ***
worth noting that the esp32 has a builtin Espressif Two-Wire Automotive Interface (TWAI) CAN interface
have a look at esp32-can-bus-demo-code-for-adafruit-adafruit-can-pal-can-bus-transceiver
the ESP32 requires a cjmcu-1051 CAN transceiver or similar to interface to the CANbus
Hi I already solved, it was a problem where I put the variables and I put them at the top:
#include <SPI.h>
#ifdef ESP32
  #define SPI_CS 5
  #define CAN_INT 4
#else
  #define SPI_CS 10
  #define CAN_INT 2
#endif
unsigned long rxId;
unsigned char len;
bool interrupt =  false;
byte is_received;
void ISR_CAN(){
  interrupt = true;
  attachInterrupt(digitalPinToInterrupt(CAN_INT),ISR_CAN,FALLING);
now the problem I have the ESP32 receives the message but only once, then it doesnt receive anything if I still send information, and the mesagge is empty
The complete code is this:
#include <SPI.h>
#ifdef ESP32
  #define SPI_CS 5
  #define CAN_INT 4
#else
  #define SPI_CS 10
  #define CAN_INT 2
#endif
unsigned long rxId;
unsigned char len;
byte is_received;
void ISR_CAN(){
  interrupt = true;
  if(interrupt){
    Serial.println("Message received");
    CAN0.readMsgBuf(&rxId,&len, rxBuff);
    Serial.println("Buffer: ");
    for(int i=0;i<8;i++){
      Serial.print(rxBuff[i]);
      Serial.print("\t");
    interrupt = false;
