Hello,
I am new to using the Arduino IDE and have been working on an ESP32 dev kit trying to communicate with CAN using the Arduino CAN library example.
Using the latest ESP32-WROOM-32E I have encountered an issue where plugging the CAN_H, CAN_L connector into my receiver pauses the system until its disconnected at which point the receiver starts to run again. I have attempted this on multiple sender side circuits but the same thing happens, the whole circuit pauses including other receiving CAN parts such as a LED strip controlled by CAN.
My question is if this is a common result of a failing CAN BUS due to incorrect termination or supply issues?
Testing the termination I have the required 120Ohm resistor on each end resulting in 60Ohm circuit resistance.
CAN_H, CAN_L are tested to have correct voltages each end, but slightly different on each end.
Using a ESP32-WROOM-32 NOT E, an older version of the chip from ESPRESSIF, it works without issue.
Thank you,
Tom
