can bus shield MCP2515
hi...can someone help me please ...i have a probleme with my can bus shield MCP2515!!!
the car that i tested with my can bus shield MCP2515 has "KWP SLOW" obd-II protocole...and i didn't know how to put it in my code like this:
"" if(!mcp2515.initCAN(CAN_BAUD_500K, CS_PIN))
Serial.println("Failed initCAN"); ""
can someone tell me what to put in the place of : CAN_BAUD_500K
and thanks :slight_smile:
alaamo9:
"KWP SLOW" is NOT a CAN protocol
can't used the shield for that but instead you could you the Serial RX pin (mind the voltage levels!) if you are only reading the data! I believe the baud rate you need to set is 10.4k
thx for the answer..but how to put 10.4 in the code??
alaamo9:
how would you print data to serial monitor?
there are plenty of examples out there to do that! :slight_smile:
give me some if you can....its 2 days i'm searching i didn't find any solution...when i used mcp2515.initCAN(CAN_BAUD_500K, CS_PIN) i get some values like rpm and intk air temp but i dont get most of values....can you give me an example of kwp slow protocole code for the can bus shield MCP2515...i want just to get values
alaamo9:
did you even understand my first reply? KWP SLOW IS NOT BASED ON CAN PROTOCOL to my knowledge!
KWP SLOW is a serial protocol.
you can try this code (googled it btw!) but again be mindful of the voltage signal level form your car or you'll damage your arduino... you've been warned
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
  mySerial.begin(10400); //10.4 kbaud
  if (mySerial.available()){
    Serial.write(mySerial.read());
now i understand ...thank you very much :grin:
